would this cam work?
Old Feb 28, 2004 | 09:22 PM
blkbrdws6's Avatar
i was wondering if the part # 08-30-8 camshaft from comp cams will work with my 1987 gta, this cam has a lift of 480/480, 112. my setup is a 355 with 9.35 compression, stock ported and polished heads, edelbrock base and runners etc..
Old Feb 28, 2004 | 11:50 PM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
Don't know the duration but lift and lobe center look good...The 112 centerline gives you a nice broad torque curve.
Old Feb 29, 2004 | 11:10 AM
blkbrdws6's Avatar
my bad, the duration is 210/220
Old Mar 1, 2004 | 07:48 AM
Car: 85 IROC
Engine: 355 CI n/a
Sounds Like you'll be happy with that cam, blkbrd. Let me know how it turns out!--Dusty
Old Mar 1, 2004 | 09:02 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You can go bigger, but for a stock replacement with out any ECM/PROM work it will work out nicely.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
