TPI at top end
Old Mar 4, 2004 | 03:58 PM
echo5blud's Avatar
Car: 1986 Z28
Engine: 305...350/383 in progress
Transmission: 700r4...fresh rebuild
TPI at top end
Me and a friend of mine were talking today, I have the opportunity to pick up a donor car for dirt cheap. I wanted to steal the TPI setup off it to go on the new motor I'm building. He told me that TPI wasn't very good past 4k. Is there anything to this? Should I consider a different injection system, or is there something I can do to the TPI to create more high end HP. I've been kicking around the idea of making my 350 block a 383. I just want to know if I should consider something else for fuel delivery.
Old Mar 4, 2004 | 05:06 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Use the search function, and you will find a lot of useful information.. This has been discussed (and is practically the primary discussion subject of this section)...
Old Mar 4, 2004 | 05:35 PM
echo5blud's Avatar
Car: 1986 Z28
yeah...but I believe the main question is....is he straight up full of poo????
answer to that being no...I found it in the banned topics section....doh
Old Mar 4, 2004 | 07:27 PM
vwdave's Avatar
Yes/no. Its really 4500, but mine with cut-out air boxes, K&N's, and ported plenum runs to 5000. Of course, I got a small-cammed 350.
For things you can do to it, do a search. There is SOOOOO much more information than I can include in one post.
Old Mar 5, 2004 | 12:51 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
If your going with a 383 you will like the HSR (Holley stealth ram) better than a stock or modified TPI. The tpi maxes out at 4500 rpms. It will choke your 383. Do the search though as its all a matter of what you like.
Old Mar 5, 2004 | 11:08 AM
echo5blud's Avatar
Car: 1986 Z28
ok...I know I want the aftermarket Fuel injection....but should I buy the donor car anyway at $400? I could easily part it out...it's a red IROC with T-Tops...I wouldn't want to sell anything under the hood...the only reason I would mess with the TPI is that it's brand new....
Old Mar 5, 2004 | 11:14 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
For $400, and if you have a place to store it while you tear it apart, I don't really think you can go wrong. The parts are worth much more than $400, even if there arent that many left.
Old Mar 5, 2004 | 02:14 PM
echo5blud's Avatar
Car: 1986 Z28
only problem is...idiot who owned it before the guy who owns it now put a top post battery in it...anyone want to hazard a guess as to what will happen if you put a top post battery in a third gen? In other words the engine compartment is pretty much trashed
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
