swap: MAF to Speed Density
Old Mar 6, 2004 | 03:38 PM
comatose 88 WS6's Avatar
Car: Chevrolegs
whats needed for the conversion? yea im a new guy, and i havent seen a how-to posted for this yet. im assuming an ecm and MAP sensor off a 90-92 car, but is there anything else? how much of a difference will i see over the MAF system in my 88 GTA? Im in the desert if climate is a factor.
Old Mar 6, 2004 | 06:18 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
You need to do a lot more research....HAHAHAHAHAHA. Its not hard but its just not a matter of mindlessly swaping parts. You have to repin the ECM harness. Happy searching and good luck.
P.S. I HAVE done this conversion and its a lot of wiring, not for a noob.
Old Mar 6, 2004 | 07:23 PM
Car: Chevrolegs
damn =/, i cant just get a new wiring harness? and by new i meant on this board
Old Mar 7, 2004 | 01:22 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
whether you're a noob or not is irrelevant. i was a "noob" when i did my SD swap and i still managed to do it. hell, i still consider myself a noob or whatever. you just need to research it and be familiar with exactly what you're doing going from maf to SD. also, mike davis' site is infinitely helpful. i would start there and check out what's involved in the repinning. it's the part that takes the longest with labeling all the wires, etc, but just make sure you keep your stuff organized and know what pins go where and you will be fine.
Old Mar 7, 2004 | 10:17 PM
carbgeek's Avatar
yea that maf meter is probally hurting you something like 50 or 60 hp too
Old Mar 7, 2004 | 11:01 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I didnt need to re-pin anything. Bought an ECM (7730) with memcal from a 350 90-92 and a painless wiring harness. Got the knock sensor that reads 3.9 0hms instead of 100 and a map sensor from the 90-92 etc. Works great.
Old Mar 8, 2004 | 10:27 AM
Car: Chevrolegs
no wonder your the captain :rockon: i was figuring with just the different sensors and one of those painless wiring harnesses would do it no prob,since my 88 has almost all the same sensors. Besides, from what Im seeing if I ever plan on running a turbo or a vortech s/c routing the maf sensor in looked kinda hard.
Old Mar 8, 2004 | 12:55 PM
Yep,
Just make sure your sensors match up for the speed density system (yrs. 90-92) and you shoudnt have any problems. Be aware that Painless lists part numbers in their manual that comes with the harness that do not match up. I bought the wrong knock sensor because of them. Just double check everything that I mentioned earlier. Also, SD isnt kind to many mods. It's not as forgiving as MAF.
Old Mar 8, 2004 | 01:14 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
speed density is very sensitive to change,if you swap cams,injectors,intake you will need to do it all together so you spend time and or $reburning chips,pretty much it seems if you go and lose weight you seem to need a chip mod LOL J/J.. but i will NEVER do mass air again!!!!!!!
Old Mar 16, 2004 | 06:44 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
v6 sd harness
How about this:
I've got a 1992 firebird 3.1L V6 SD (stole it for 300 bucks!) that I want to put a 350 TPI in. Can I use the existing wiring harness and ECM , just changing the prom?
Old Mar 16, 2004 | 07:47 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: v6 sd harness
Originally posted by mmcdjs
How about this:
actually thats what i made my first harness from.....all i did was add 2 more injector wires to the injector harness.it worked fine using the stock v6 prom........but then i upgraded to a painless harness and added the v8 prom
Old Mar 18, 2004 | 09:42 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Hey captain, how much was the painless harness to convert maf to map ecm, and what is the part number of the correct harness?
Old Mar 18, 2004 | 09:46 AM
mmcdjs's Avatar
Engine: 3.1 V6
You were able to use the 3.1L memcal in the 350 engine? I didn't think that was possible! the 730 ECM for the 350 has the $8D mask and the 3.1L has a $88 mask, the prom is completely different! Enlighten me if I'm mistaken on this.
Old Mar 18, 2004 | 02:58 PM
Car: Chevrolegs
put that in a diff topic
damn, just jackin my thread i see....90+ ecm, 90+ sensors, and a painless wiring harness, sounds easy enough.
Car: Chevrolegs
89gta jegs has painless wiring harnesses, not sure the price though
Old Mar 22, 2004 | 06:32 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
they use the same ecm
Old Mar 22, 2004 | 08:17 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
Re: put that in a diff topic
the painless harness is anything but
look at my thread (The Street and Performance wiring harness)
Old Mar 24, 2004 | 02:20 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Hey Commatose
Check your email. I just sent you a bunch of information on the swap.....
Old Mar 24, 2004 | 04:01 PM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Re: swap: MAF to Speed Density
Here's your how-to:
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
I just did the swap two weeks ago using this guide and it was easy. Also visit the prom board, as your really going to need to learn how to tune once you do this swap. If I couldn't burn my own proms my car would be out of commission until I learned to burn them or paid some one $$$.
Old Mar 27, 2004 | 11:32 PM
Car: Chevrolegs
thanks captain
Old Mar 28, 2004 | 12:39 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
not to be an a$$ but may i ask y your car is stock and unless your maff is blown the thing works fine i plan on keeping mine till i get some boost then ill go with a dfi or some thing
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
