few question about LT1 cam and my car
Old Mar 6, 2004 | 06:52 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Would putting the LT1 cam in my car move the power band up father than what it as with peanut cam since the car came with the peanut cam and not the LT1? and if so why?
I dont know if its the car or just me cause I havent driven the car in so long but it feel like I have lost low end...could it also be that since I have put the LT1 cam in and still running my 2.73 gears...they do not like eachother? and if so why?
Would getting a stall and new rear gears such as 3.42's make my car feel like it used to and give me my lowend back?
It may just be me but maybe you guys know more about it..
thanks!
Old Mar 6, 2004 | 10:11 PM
step inside you guys with the Lt1 cams in your car..I know your out there...
Old Mar 7, 2004 | 09:03 AM
Oh well, sometimes someone know and then again sometimes nobody knows the answers...I'll keep searching..
Old Mar 7, 2004 | 01:23 PM
SpeedJunkie's Avatar
Car: 88 IROC
I would assume that with your 2.73 rear end and the lt1 cam it would move the power band up and your rear end would make it seem even worse. I am actually in the middle of doing this swap but I am putting in an lt1 rear with 3.42 ratio. I bet that thing would haul *** in the upper rpms on the highway though!!
Old Mar 7, 2004 | 05:42 PM
you basically got the same setup as me......I can tell I got more power but it feels like it moved up...when I would normally have ran in 4th or even 3rd....sometimes I can drop it down a gear to make me feel like I have some power cause if I keep it in the gear when my rpm's are so low and punch it there just isnt any power like I would think. Maybe it is my gears...I hope so...
I can run 70 on the highway and only be doing about 1800 rpms....thats in 4th and when I drop it down to 3rd I feel like I have the power I need..I feel like I can even drop to 2nd but I havent tried that yet..kinda scared to!..LOL
and it didnt used to feel that way when I had the stock crappy cam in...
Old Mar 7, 2004 | 09:36 PM
Car: 88 IROC
Its goota be cause the power band moved up a little with that cam so the torque is still there but itsa moved up and the gears are still searching for it down low but its missing
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
