strange fuel pressure/pump problem
Old Mar 9, 2004 | 07:17 PM
Tier's Avatar
I'm having fuel trouble with an 85 tpi engine. I now have my second aftermarket inline fuel pump(thought the first went bad). The engine won't go over 2500-3000 rpm's. The fuel pressure is normal at idle, but will go down to 20-30psi when trying to accelerate. Fuel is flowing freely to, and from the fuel pump and filter. The fuel pump makes quite a bit of noise, and runs often.(Same thing was happening to the other fuel pump.)
What I have tried:
-New fuel pump
-new fuel pump relay
-checked over/fixed some fuel pump wiring
-new adjustable fuel pressure regulator>This was put on several months before the problem started.
If anyone has any advice I would appreciate it.
Thanks!
Old Apr 5, 2004 | 01:22 PM
cbmotorsports's Avatar
Car: 1988 GTA
Engine: 5.7
GREAAAAT
I am having the same problem with my 91 tpi. Have you gotten anywhere with it? Mine does not have a problem until about 4g. I see that nobody has responded. Not a good sign.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
92camaroJoe
Aug 13, 2015 06:07 AM
