Ok, where the heck is it?
Old Mar 11, 2004 | 05:09 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Where the heck is the MAP sensor on my car? I need to replace mine and I can't seem to locate the old one. GM said it was part of the MAF sensor and yet I just bought a MAP sensor at the parts store. Hmmmmm.
Old Mar 11, 2004 | 05:12 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You dont have a MAP sensor on your motor. You have a MAF sensor (which is located between the throttle body and the air filter).
MAP sensors came on cars equiped with speed density TPI (90-92 F-body's).
85-89 TPI F-body's came with MAF's.
Old Mar 11, 2004 | 05:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have an 86 TPI, unless you or someone else has changed your system over, you do not have the MAP sensor. You have the MAF Sensor on your car. The MAF sensor is located between the air filters and the throttle body. What makes you think you need a MAP sensor anyway?
Old Mar 11, 2004 | 06:06 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Because I have a code 33 coming up every now and then. My oil pressure gauge seems to be high untill the vehicle reaches operating temperature also.
Old Mar 11, 2004 | 08:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That doesn't neccessarily mean that you need a new MAF sensor. You could have a broken or shorted wire between pin "C" of the MAF sensor (dark green wire) and pin "B12" of the ECM. That is the signal wire for the MAF sensor. I don't know how high your oil pressure is, but mine is usually up there around 50 or so until the oil warms up and starts to flow smoother.
Old Mar 13, 2004 | 07:11 PM
levi's Avatar
Car: 1986 IROC, 1983 Camaro Convertible
Engine: Both 305
Transmission: Both 700-R4
My brothers car had the same code and it turned out to be a bad wire by the conector.
Loudnproud86
Jul 14, 2016 12:59 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
aharvel50
Sep 21, 2015 07:31 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
