TPI Install question
Old Mar 21, 2004 | 04:40 PM
bad_azz91's Avatar
Car: 1991 Camaro
Engine: 383
Im building a 355ci 380hp engine and i was planning on running a TPI setup to top it off. What factors should i look at replacing in a older TPI setup like from thirgenresource.com to make this engine perform best? I know about larger injectors and maybe some better runners/throttle body, but any other suggestions like about the computer and stuff would be nice.
John
Old Mar 21, 2004 | 08:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
For your HP level, disegard the factory setup.
All you'll be using is the ECM and wiring harness.
Look into piecing something together...maybe a Holley SR, etc.
The long run cost will be less expensive.
Old Mar 21, 2004 | 10:16 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
Mike is right about the price, believe me it just keeps adding up. I'm running a TPI on my 355ci and I should be close to 375hp. I've changed just about everything, all sensors are new, I put an Holly adjustable fuel pressure regulator, 24lb Accel injectors, Edelbrock Hi-Flow intake, SLP siamesed runners, ported plenum, hypertech cap, rotor, and coil kit, and the list goes on and on. In about a month, I'm going start playing with programming a custom chip. Of course, I'm kind of partial to the TPI so I didn't mind spending a little more to make it run right.
Old Mar 22, 2004 | 07:40 PM
91blackgta's Avatar
bump
Old Mar 22, 2004 | 10:06 PM
Abubaca's Avatar
First off, don't buy from Thirdgenresource. Don't take my word for it, do a search on the vendor board.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
