gas vapor smell
Old Mar 21, 2004 | 12:31 AM
poody's Avatar
gas vapor smell
Need help, I have a 91 camaro with a 350. It seems that whenever it gets warm outside and I go for a long drive, I can smell gas vapors. It doesn`t happen on cold days. Anyone have any ideas.
Old Mar 21, 2004 | 08:14 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
check your gas cap, if its the vented one there is your criminal, and check the lines to your charkoal canister....
Old Mar 21, 2004 | 09:15 PM
LinuxHead's Avatar
Car: 1986 WS6 Trans Am
Engine: TPI 305 (LB9)
Transmission: 700-R4
My '86 TPI had the same thing. Pulling the gas tank and resoldering the filler neck joint fixed it.
There's supposedly a recall for this on some years, but Pontiac claimed it doesn't apply to mine.
Old Mar 21, 2004 | 09:34 PM
jonarotz's Avatar
Car: 91 Z28
I have the same problem with my 91 Z28. I did some research on this and have found what LinuxHead says is true. There was a tech bulletin on the joint where the filler neck meets the tank. It stated that the weld/solder comes loose and allows vapor to leak. I have not felt energenic enough to crawl under the car and fix it so i do not know how involved it really is.
Old Mar 21, 2004 | 10:00 PM
poody's Avatar
So, if there was a recall on the neck of the gas tank, chevy wouldnt fix it now? OR would they. Dream on right: )
Old Mar 21, 2004 | 11:08 PM
jonarotz's Avatar
Car: 91 Z28
You got it,
Dream on!
I think they only only honor the recalls for a certain time period from the date that they were issued.
Old Mar 22, 2004 | 08:41 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
a technical bulletin is not a recall.
a technical bulletin is put out by the manufacturer to help the technicions figure out a problem
there is a big difference.
Old Mar 22, 2004 | 10:28 AM
jonarotz's Avatar
Car: 91 Z28
Right, I was only saying that if there was a recalll it would only be honored for a period of time. Either way(tech bulletin/Recall) we have to fix it ourselves.
Old Mar 22, 2004 | 10:31 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I'll second the gas cap, weird how vapors can travel forward at 80mph?? A new cap fixed mine.
Old Mar 22, 2004 | 07:14 PM
poody's Avatar
also when its hot out and the vapor smell is there, It sounds like the gas tank is purging itself underneath , it sounds like something is openning then closing, Im assuming to get rid of pressure.
Old Mar 22, 2004 | 07:24 PM
poody's Avatar
Could anyone tell me how I would go about fixing the problem myself.
Old Mar 22, 2004 | 11:44 PM
jonarotz's Avatar
Car: 91 Z28
If you have a vented gas cap start there. I would then look at all of your charcol canister lines where they meet up at your tank. Then I would inspect your fuel tank where the filler neck enters the tank. I don't think trying to resolder it would be very smart because of the fuel and vapors. Maybe some epoxy would do the trick. Hope this helps.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
