acceleration pops
Old Mar 21, 2004 | 06:00 PM
GTABANDIT's Avatar
acceleration pops
Ok breakin in the mini rammed afr 195 383 and noticed upon sharp crack of the throttle it has an intake pop . I am running custom burned prom with 24 lbs inj and 6 deg initial timing . my fuel pressure is set at 46 lbs . Could the pump shot in the chipbe to lean? any suggestions thanks!!:hail: :hail:
Old Mar 21, 2004 | 06:17 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
that is possible,does the pop do it in the same rpm or same spot the accelerator is at if so i would definately replace the TPS.
Old Mar 21, 2004 | 06:36 PM
GTABANDIT's Avatar
Replaced tps and adjusted to specs checked fuel pressure but only at idle not during the drive. it has a walbro 255 pump in it
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
