tpi replacement fuel lines
Old Mar 23, 2004 | 05:37 PM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
I keep hearing about people having braided stainless line custom built for their cars particularly in intake or engine swaps where and how can I get a set of these made? scooted45@yahoo.com
Old Mar 24, 2004 | 05:36 AM
traumatech's Avatar
My dad is going to be custom making these -- this is the prototype on his corvette race car.
File Type: bmp
Old Mar 24, 2004 | 05:44 AM
traumatech's Avatar
Here's a link to a bigger picture of it.
Old Mar 24, 2004 | 07:34 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Re: tpi replacement fuel lines
www.summitracing.com
Measure where you want to run the line
You buy amount of line you need + extra
Buy the necessary ends
Cut the lines to length
Put the ends on
Attach everything
Check for leaks
go
http://www.celligent.com/tim/iroc/progress/P1002006.jpg
Tim
Old Mar 24, 2004 | 08:10 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Hey, Traxion --- Nice looking engine! Real clean engine bay, too. One question for you: It looks like you're running two breathers (one on each side) and no PCV valve, is that right? Please excuse my ignorance, but is that really accomplishing anything? I thought the whole idea was to run a PCV on one side and then a breather on the other side to more or less "vent" the draw from the PCV. Am I missing something? Just curious, even an old Phat Phart like myself can always stand to learn something new....
Have a Great Day!!!
--- Vern
Old Mar 26, 2004 | 01:13 AM
scooted45's Avatar
fuel lines
what kind of aftermarket an fittings use oem style male externally threaded fittings with o-rings? I dare say that the engines shown in your pictures while fine examples of craftsmanship are using other than stock components in the area of fuel delivery. Traxton, that engine bay is what dreams are made of. Is that ac delete a gm part? I also like the delete plate on the fire wall very clean looking. Scooted45@yahoo.com
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
AkDrifted
Aug 17, 2015 07:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
