is there a timing chain w/ precise timing adjustment
Old Mar 23, 2004 | 05:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am looking for a timing chain that has a more accurate timing adjustment setup on it. I seen a seup on a ford engine where you could tun the top gear a little bit to dial the cam in perfect and then just tighten the bolt up. Is there somethng like that for the SBC with a roller cam? I dont need anything exspensive. If nothing is offered then how well will a cloyes true roller kit work out
Old Mar 23, 2004 | 06:30 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes,
Cloyes hex-a-just timing chain. I originally thought that they didn't make one for roller blocks ... but THEY DO! I bought one and installed it during my last cam swap.
Tim
Old Mar 23, 2004 | 06:33 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
manley also makes one that the cam gear is adjustable.
Old Mar 23, 2004 | 07:55 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I'd go with the Rollmaster billet steel timing set. They make them for older sbc's and 87 up roller sbc's too. It uses a JWIS chain which is the best available. You can even get them nitrided. Try www.competitionproducts.com They are the best place to get them.
Or you could get really rad and buy a cam-correct system. That's probably the type of setup you seen on that ford motor. COMP even makes a copy of it, but I don't think they offer them for 87 up motors.
Old Mar 24, 2004 | 04:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
Traxion, what is the part number for the Cloyes timing chain? what is the part number
Old Mar 24, 2004 | 05:59 PM
TRAXION's Avatar
http://www.cloyes.com/images/CloyesH...rmCat-2002.pdf
I think it's 9-3145A
The 'A' is the important part.
Tim
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
MY87LT
Aug 17, 2015 08:43 AM
perZ
Aug 15, 2015 01:17 PM
