will code 36 effect performence?
Old Mar 24, 2004 | 08:09 PM
iroc88ohio's Avatar
Car: 88 iroc
Engine: 5.7
i have the good old code 36 and i was wondering if it will effect performance? thanks
Old Mar 26, 2004 | 08:41 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
It most certainly will.
This would be your MAF Burn Off Relay and probably about 12 bucks to fix.
Any trouble code like this sends your computer into "limp home mode" which enriches the fuel mixture, prevents closed loop, prevents TCC lockup...... or translated means your MPG just got cut in half.
Red 86 T/A 5.0 TPI (LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Plenum ~ Pirelli 245/50/16
~SLP TB Airfoil ~All Else Stock
Old Apr 1, 2004 | 11:18 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
how would one go about fixin it?
Old Apr 2, 2004 | 06:48 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Code 36 could be a simple fix if it's the burnoff relay.
I would switch the burn off relay with the power relay.
Then disconnect the battery for a few minutes and recheck the codes.
If the code changes (to a 34 I think) then the relay is bad.
About a 12 dollar fix.
I don't know where they are on a Camaro but they are here on an 86 Trans Am:
Last edited by MikeInAZ; Aug 20, 2006 at 11:41 AM. Reason: convert html to bb code
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
