Will these heads fit my 88 TPI motor?
Old Mar 29, 2004 | 09:20 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6783
Double hump
194 valves
Casting # is 3890462
Dates are 1 1 6 + 1 6 6
Will they fit my 88 block? Or is the roller block different?
Would it be worth it to do?
Old Mar 29, 2004 | 10:43 AM
Everett#2390's Avatar
Car: Several
Engine: A good heart
Transmission: Long legs
Here ya go:
3890462....66-67...302/327/350..Camel hump,no accessory holes,64cc chamber
These will work, but, accessories will have to be removed or use 67 & earlier mounting brackets, as they bolted accessories to the exhaust manifold & intake, rather than bolting onto the front of the engine. Also, these heads used washer sealing spark plugs, ie, 13/16 socket size.
I'd go for a set of 492's, they came with accessory holes and used tapered seat spark plugs, ie, 5/8 socket.
Old Jan 15, 2013 | 08:40 PM
CradleofFilth08's Avatar
Car: 1992 Camaro Z28
Transmission: 86' 700R4
Axle/Gears: 10 Bolt, 3.42's
Re: Will these heads fit my 88 TPI motor?
Hate to revive an old thread BUUUUT....will these make much difference over our stock L98 heads? Got a guy local selling a set for $200.
Old Jan 15, 2013 | 10:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Not worth it at all.
Frozer!!!
Jan 19, 2024 04:55 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
slade5612
Aug 11, 2015 07:19 PM
squiggy2
Aug 9, 2015 09:30 PM
