HELP ME THIS TIME!!!!soon time up!!!!tpi to ???
Old Apr 2, 2004 | 07:13 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
i have a 305 tpi and it was brand new rebuilt. 0km i put the engine in the car and 2 injector leak in the piston chamber and when i turn the keyi warped two rod. so the guy installed the injecton in the block so its still his fault and he offer me to rebuilt a 1974 4 bolt main 882 heads for free/or rebuilt my 305 actually cammed to 464 470lift 210 215dur0.050 lobe sep 110deg.flat top piston. and the guy suggest me to put a mecanick cam to the rebuilted 350 and i can chooose the cam. i dont know if the 305 setup was good never had time to know!what should i do. plz help should i go to carb? plz answer soon
need to decide before next week end need as muck info as possible before this date!!
any suggestion what i should do??? anything HELP ME!!!!!
i know how to remove and install my engine but im not really *** at what should i do to make it faster or work if its not bolt on!
sorry again...crappy english..
Old Apr 2, 2004 | 08:39 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
The 882 heads are (crap) prone to cracking. I would stay away from them on any kind of performance engine. BTW, I learned the hard way through personal experiance.
Don't worry about the english, I was born and raised here and I still can't spell worth a flip.
Bill
Old Apr 3, 2004 | 12:25 AM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
Go the 350 route. I'ed suggest some different heads tho. You can find used L98 350 heads CHEEP and you can keep the TPI setup and you'll just need a chip for a 350 and your 19lb. 305 injectors
will work for now and you can upgrade to 22lb. injectors later as time and money allows.Anyway thats what I would do.
Old Apr 3, 2004 | 09:14 AM
FOX-GTA_89's Avatar
yeah thats what i wanted to do but it seems that the flywheel /MAF/sensors/oil pan dipstick/flat tappet cam with injection wont fit true?
Old Apr 3, 2004 | 07:21 PM
mike89-350's Avatar
Car: 89 formula 350
Engine: 355
You will have to get a flywheel for an older model crank, and you will have to get a dipstick for the driver side but they make flat tappet cams for tpi and all the sensors will bolt up.
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
Sanjay
Aug 12, 2015 03:41 PM
