Vibrations!!!!
Old Apr 2, 2004 | 11:53 PM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
It has a vibration after new engine!!!
Ok well first off, I seem to be experiancing vibrations from somewhere I have ideas to what it could be. So I need some other ideas.
Ok I just recently dropped a 76 350 block in my car, still has tpi, changed cams, bigger cam, forged pistons, ported and polished heads.
Well when I had to get a flywheel I had to use a flywheel off a 85 305 camaro. Well I don't know if its the Flywheel or not thats causing it. Could it just be the cam is bigger, or something. It has the orginal prom for the 305 that I had in it, and I haven't recieved my new prom yet that I had custom burned to my engines specs, so maybe its just the rough idle or something I really don't know, but the car has a vibration that is fairly noticeable, but doesn't really vibrate bad when at higher RPMs. Any ideas??????If you have an idea drop me a note, thanks guys!!!!!
Tyler
Old Apr 4, 2004 | 10:07 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
just by chance did you install a new transmission mount?....i put a prothane on mine and the vibration was terrible around 2000 rpm....just my .02
Old Apr 4, 2004 | 11:56 PM
snowman89's Avatar
Engine: 5.8L 355
yes I got a poly one. and it doesn't look like the engine shakes though....
Old Apr 5, 2004 | 12:42 AM
DON 88T/A's Avatar
I would imagine that 305 chip does not like the setup at all and is stumbling /hesitating pretty bad...otherwise just make sure the tranny mounts/driveshaft bolts/u-joints are tight and in good shape....
Old Apr 5, 2004 | 09:04 AM
snowman89's Avatar
Engine: 5.8L 355
yeah thats what I'm thinking. Cuz it Idles like ****!!!! other than that it runs good, with minimal vibration. The engine doens't look like its vibrating when its Idling. Neither does the tranny or anything. I guess it could be the lopy cam. It doesn't really get to violently vibrating when I'm accelerating, mostly just when I'm idling. It doesn't always wanna stay running either.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
