About tightening trottle cable
Old Apr 3, 2004 | 10:43 AM
john_iroc's Avatar
Car: 89 Iroc-Z
Seens like my cable is too loose, I've read that its not good to tighten becuase it could break the cable. When i go under my hood and open the throttle its ok, but inside the car when i push on the gas its not the same response as to opening the throttle body under the hood. Anyone have any suggestions?
Old Apr 3, 2004 | 02:26 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Well have you looked to make sure that when the go pedal is all the way to the floor the throttle blades are all the way open? If not check it, then if not you can bend the arm of the pedal to take up the slack.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
FormulaEngland
Sep 30, 2015 01:50 PM
