factory roller blocks???
Old Apr 4, 2004 | 10:23 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
how much lift can you go with the stock roller litter befor you need aftermarket lifters
thanks
Old Apr 5, 2004 | 11:29 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you are talking about our hydraulic roller lifters, the max lift is mainly limited by the valve spring. If you intend to go above the stock lift (or the stock springs are old), then you should purchase and install new springs which are designed to handle the lift you are going to use.
FWIW: I am biulding an 395 cu in engine having .525" lift. For this usage, I bought dual 987 (I think) Comp Cams springs.
Old Apr 5, 2004 | 01:34 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
I believe that you can do about .380 lobe lift (~575 at valve), before the lifter body will push up on the lifter retainer, and therefor the the spider leg. I spoke with both Crane, and Comp about this because this may be exactly why I kept having lifter, and valvetrain problems (and now am solid roller). I could be wrong, but that is what the cam techs told me. Good luck with your build-up!
Jorlain
Oct 8, 2015 01:57 AM
MoJoe
Sep 24, 2015 09:12 PM
SlowAZ28
Sep 2, 2015 05:19 AM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 8, 2015 09:37 PM
