car is really pissing me off
Car: 85 trans am
Engine: 350 4bm TPI
i have an 85 t/a with a 350 tpi {350 is out of a 60 something van}
I just replaced the egr valve and temp switch, started her up and she ran fine, so i took her around the block and shut her down. The next day when i started her up she just died, but if i step on the gas she won't stall till i let off, tried this bout 10 times, the 11th she started right up but the 12th thru 20th same thing, this is really starting to **** me off. the only codes that are being thrown are the O2 sensor cause i don't have that put in right now, i know that the O2 sensor can't be the problem.
Any ideas on what to check next
Car: 85 trans am
Engine: 350 4bm TPI
but the 02 has been out for bout 10 months and this is the first time it's done this. I also noticed one of my cables i think throttle (the one on top with the black connector, not one of the ones with the pins holding it on) is a little bit bent, and i think i streched it a little gitting it back on. Would that at all cause the car to die at idle???
Linson
Aug 21, 2015 02:12 PM
