blew engine computer's fault of injectors?
Old Apr 8, 2004 | 12:49 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i blew a brand new motor because a fuel lock append in 2 cylinder so when the piston tried to compress the cylinder full of gas i bent 2 rod and the crank. its waranteed, the guy is actually rebuilting me a 350 instead on the 305 that blew . the guy sait that it was the injector that was wrong but why the where ok before and 2 of them would broke at same time possible??? other guy at the local auto part think that is the computer that is going crazy possible have any answers??
dont want to blow my new 350 what i should do??
and how to check in injector are good???
Old Apr 8, 2004 | 01:31 PM
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
they have a tool out there that is pricey if you want to buy it but they are called injector noids or pulsers.any shop that works with fuel injected cars has them,basically what it does is check to see if the injectors are getting the voltage pulse and tells you which ones are bad.
Or if you can get the car over to haliburton ontario,i got a buddy that owns a shop there.
Old Apr 13, 2004 | 02:01 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
You can always send them off and get them checked. TPIS does it as do others.
Old Apr 13, 2004 | 09:26 PM
mbtech's Avatar
Car: 83 comaro
Engine: 350 tpi
Transmission: 350
fyi the noid light is only about $10 i just bought one from mac tools (bosh style ) Id check the injectors it self by using shop air with a blow gun and see if it leaks. If all ok check head gasket
IroczFan
Oct 6, 2015 10:13 AM
masonta
Aug 31, 2015 10:14 PM
Jae992
Aug 27, 2015 09:07 AM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
