58mm tb for stealth ram
Old Apr 13, 2004 | 03:01 AM
pontiacpete's Avatar
just wanted opinions on which brand to settle for edelbrock , holley or bbk?
Old Apr 13, 2004 | 07:59 AM
Formula383's Avatar
Car: 88 Firebird Formula
Don't get a Holley. I had probs w/ the TB sticking. Dosen't mean everyone else had that prob. Just my .02$. I have a BBK 58MM TB on my LT1 converted intake. Works real nice.
Old Apr 14, 2004 | 04:02 AM
is bbk and edelbrock made from the same company?
Old Apr 14, 2004 | 06:15 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I think 58 mm is too big for most motors. The 502 Ramjet uses a 48mm. I've heard good and bad about all of them. I think BBK is usually pretty good stuff.
Old Apr 14, 2004 | 07:25 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Use the search function Before you dish out the money for a 58mm Throttle Body and make sure you need one.
Unless You are pushing some SERIOUS HORSE POWER you shouldn't need it.
some people actually lost a little power buy switching because Let more air in but slowed down the velocity. Don't quote me on this, use the search button and Find out.
Also Update your Profile to display you Engine Mods and Specs in your Signature. It helps to know what your Set up is like before anyone offers Recomendations.
Old Apr 15, 2004 | 02:35 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I have a Holley 58mm TB. I bought it to match the HSR (Holley product). I had the BBK. It depends on what you want for looks. The Holley is made with better quality material and looks nicer. The BBK wasnt anything beautiful to look at IMO but it did the job just fine (it was also a 58mm). I also have a 3 1/2" custom cold air intake snaked down through my unused battery plate where my canister was. I am sucking in 1000cfm's of cool air. Then again, I also have a 500hp 406sb. It likes lots o' air! It is true that if you are running close to a stock setup you dont need 58mm. I would say 52mm max. Hope that helps.
Old Apr 24, 2004 | 10:14 AM
willis2z's Avatar
Car: 1989 IROC Camaro 1LE
Engine: 383
Axle/Gears: Dana 3.55
Just to let you know I'm running a stock tb and running mid 12's.if your running near stock or a mild cam you should't need it.Unless looks is an issue.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
