Ford injectors w/tpis intake, slp runners?
Old Apr 13, 2004 | 01:47 PM
dd85T/A's Avatar
Car: 85 T/A
I have a TPIS intake with SLP runners. I just got a set of Ford 24# injectors and the person doing the install says they won't fit.
Is anyone using the Ford injectors with an aftermarket intake and runners? Any problem getting the injectors to fit? Did you use the clips? It seems the injectors are 1/4" longer than stock and the fuel rail won't fit between the intake and runners. Has anyone had this problem?
Old Apr 13, 2004 | 02:25 PM
dd85T/A's Avatar
Car: 85 T/A
Forget all the above. When he assembled everything he found that everything fit fine. I guess the injectors go in further in the intake. Sorry for my panic attack.
Old Apr 13, 2004 | 02:39 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
those clips are there for assembly line purposes.
The inj will not come out of the fuel rail once bolted down inot place
later
Jeremy
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
