Does anyone have the LT1 plenum on their L98 SR??
Old Apr 15, 2004 | 08:04 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Just wondering if anyone is using the shorter Plenum?? LPE sent me the short LT1 style, but I am worried the plenum volume will change drasticly because of this!! Should I send it back, or keep it??
Old Apr 15, 2004 | 09:07 AM
OMINOUS_87's Avatar
Wow thats crazy, never heard of that mix-up before.
What does it look like, how much shorter?
I would send it back.
Old Apr 15, 2004 | 09:09 AM
Car: 91Z
Ya I think I am going to. It is just 2"deep instead of 3", everything else is the same. The guy said he sent it to me for extra clearance.
Old Apr 15, 2004 | 09:10 AM
red87iroc's Avatar
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Send it back.
I was just reading John's Small Block Chevy Performance book last night, and he said in the book that the shorter plenum is less than optimal, and because of the shorter height, the turn of the air into the runners is not as smooth as with the full height plenum.
He further said it was a design compromise to make the SR fit under the 4th gen hood.
(Edit: The book said the height difference was 5/8 inch.)
Old Apr 15, 2004 | 09:11 AM
Car: 91Z
red87 THANK YOU!!!! I was debating, now I am sure, again thanks bud!!
Old Apr 15, 2004 | 09:41 AM
OMINOUS_87's Avatar
What a joke, why the heck would they send you a plenum and say they are hoping you would get better clearance. There are countless 3rd gens that run the standard plenum with no problems at all.
Sounds to me like they were trying to dump some inventory on you.
I would demand they send you the right one with prepaid return shiiping so you can send back the wrong one, at their cost.
About the size, the last thing you want to do is shrink the plenum volume on a long runner intake. The plenum in effect stalls the airstream and allows it to build up and become more dense in the plenum. This is important as the sonic wave tuning of the runners then has a denser charge to push down the runners into the motor.
There are 2 reasons why the SR blows the TPI setup away:
1. Bigger plenum.
2. 3" reduction in runner length.
Old Apr 15, 2004 | 09:50 AM
Car: 91Z
The guy is making it sound like I am wrong!! It is pissing me off. They are paying the shippping now atleast. He keeps telling me he does not think it will fit?? Nice guy, but needs to learn more about his parts. Thanks for the heads up OMINOUS, I am shiping it back today.
Old Apr 15, 2004 | 09:59 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
do a 5 second search on TGO for some superram pics. print out 6 or 10 of them.... prefably several on a single sheet.
attach pictures to returned superram. :lala:
Old Apr 15, 2004 | 10:05 AM
Car: 91Z
I put 3 pics in the box already!!LOL Great minds think alike I guess.
Old Apr 15, 2004 | 10:12 AM
OMINOUS_87's Avatar
Add mine to your list, OMG is that an STB over the plenum???
Clearance my ****, lol!!!
I did have to remove some hood supports though to clear the STB, but not the plenum alone.
End of story.........
Old Apr 15, 2004 | 10:33 AM
Car: 91Z
That is one of the best pics, I'm gonna use it if you don't mind. Your car must haul ***, do ya have any times yet?? I think I saw your post with a dyno run. I was very close to buying E-Tecs, then backed out for the AFR's.
Old Apr 15, 2004 | 11:04 AM
OMINOUS_87's Avatar
Times will be had tomorrow, forecast is good right now.
I have been fighting the weather to get on the track for the past few weeks.
I dynoed a few weeks back.
325RWHP/440RWTQ (SAE)
Those numbers were had with the stock 48mm TB, LOL, a current choke point for my 385 stroker motor right now. She peaked HP at 5800rpm, so the ported intake and ported heads are flowing enough for the big 385 but the TB is just not flowing enough through the intake. However the track will be the true test to see how everything is dialed in and working together.
Old Apr 15, 2004 | 12:01 PM
Car: 91Z
That car must pull hard, I am thinking that I should have went with the comp cam everyone is using with the super ram, it has a bit more in it than the 219/219. What cam are you running?? Be sure to post those times, provided you get traction, you should drop some awsome #'s!! Good Luck.
Old Apr 15, 2004 | 12:14 PM
red87iroc's Avatar
Engine: none
Transmission: none
Wow! Lot's of replies!
Glad to help, 91wtROH17's.
Sucks to know the people on the phone at LPE do not even know details about their own merchandise. Good thing for boards like this.
Old Apr 15, 2004 | 01:01 PM
Car: 91Z
You got that rite!! Thirdgen.org Rocks.:rockon: :rockon:
Old Apr 15, 2004 | 01:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ive never seen a superram on a LT1.
anyone have any pics?
Old Apr 15, 2004 | 01:30 PM
Car: 91Z
I took some pics of the plenum and runners in the box, I will try to post them later for ya.
Old Apr 15, 2004 | 01:46 PM
OMINOUS_87's Avatar
Comp XR276HR-12 is what I have now. Its a great cam.
224/230 .535/.540 on 1.6 @.050
However if I knew then what i know now when I built the motor my choice would have been different. If I had to do it over again I would have gone with a custom Crane solid roller.
228/228 .575/.575 on 1.7 @.050
There is a good chance I will dump that cam in favor of the solid roller. However depending what the track times deliver I may just forget about it all together. However at this point my budget for parts is broke. My next purchase really needs to be a larger TB as I need to dump the stock 48mm unit in a bad way. After that I really need slicks in a bad way.
Old Apr 15, 2004 | 02:02 PM
Car: 91Z
I think you have the cam I was talking about. Let me know if you take it out and want to sell it.
Old Apr 15, 2004 | 05:51 PM
Car: 91Z
Pic of LT1 plenum:
Old Apr 15, 2004 | 06:38 PM
OMINOUS_87's Avatar
It wont load
Old Apr 15, 2004 | 09:26 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
What the guy is refering to is the shorter plenium will clear the wiper motor without as much trouble. With the 3" plenium the plenium may hit the wiper motor. My superram with the 3" plenium hits the wiper motor and I had to modify the wiper motor to fit the Superram in place.
Old Apr 16, 2004 | 08:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Pic of LT1 plenum:
you cant link to a file thats on your hard drive.
you need to put it on the internet first.
when you reply to the thread, look below the box you type the message in.
theres a button called browse... click it, select the image you want, then post your reply.
FormulasOnly
Jul 23, 2018 08:47 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
19
Oct 6, 2015 12:27 PM
