Who's AFPR
Old Apr 16, 2004 | 02:27 AM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
Who's AFPR
I was rummeging thru some junk at my buddys and came across a fuel rail that had a AFPR on it. He said I could have it. It has a recessd adjusting screw in it that accepts a allen wrench. I took it apart and the rubber in it is fine but the spring is a little rusty,so is the inside of the outter cap.Can I sand out the cap and clean up the spring or should I throw it away and buy a new one. There's no manufactor name on it. Any idea who it's made by?
Thanks for any help you guys can give.
Old Apr 16, 2004 | 10:16 AM
tpi_roc's Avatar
For the most part the only difference of an AFPR is the cap, if you can clean the cap up you can buy a new spring/diaphram etc.
Old Apr 16, 2004 | 06:40 PM
VeTTnEss's Avatar
Car: 89 Iroc , 96 Vette
Engine: 355, 350
Transmission: th-350, zf-6 spd
Actually the cap has a hole thru it and the adjuster screws onto the dyaphram assembly and the part that the allen wrench go's into has a O ring around it and it pokes up thru the cap. So I couldn't just reuse the cap on my stock dyaphram assembly without brazeing a nut onto it like the tech artical describes found elseware on this site.
By the way I'm not VeTTnEss I'm just useing his computer.
Old Apr 18, 2004 | 08:37 AM
Anybody? I'ed like to know who it's made by so I can order just the diaphram from them.
Old Apr 18, 2004 | 09:30 AM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
As far as I know AFPR just stands for adjustable fuel pressure regulator.
Old Apr 18, 2004 | 09:50 AM
I know what it stands for I just need to figure out who made this one.
Old Apr 18, 2004 | 12:50 PM
Morley's Avatar
You can use the stock diaphram in it, the only thing that makes it adjustable is the screw going through the top. Other than that it is the same as stock.
Old Apr 18, 2004 | 08:14 PM
The hole in the top is about 3/8 and the screw is actually a cap with a allen head recess in it.When you take the top off ,the cap stays attached to the diaphram and it has a O ring on it to prevent gas from leaking out around it when the top is attached.
Most AFPR's have some sort of bolt going thru the top and contacts a disk that rides against the diaphram.
Mine attaches to the diaphram.
Old Apr 19, 2004 | 12:08 AM
Morley's Avatar
Weird, never heard of one that attaches to the diaphram like that or that has that big of a hole in the cap, or even an O ring...there isn't supposed to be any gas above the diaphram, just vacuum.
Nothing stamped on the cap anywhere? A name or part number?
Old Apr 19, 2004 | 09:47 AM
Your rite ,The O ring is probably to seal against vaccume.
There are no numbers or anything on the cap.The cap does have 3 recesses in it which help center it when you bolt it down over the diaphram.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
