GOOD question
Old Apr 21, 2004 | 03:55 PM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
GOOD question
Yeah the L98 isnt a popular engine because it has 2 bolt mains but what have yal got out of the L98 (with stock intake) before putting a 383 or another 350 in? Im planning on putting in AFR heads and a 450 lift cam as of now im running a 14.1.
Old Apr 21, 2004 | 04:11 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Theres nothing wrong with a 2 bolt main, some will argue that a 4 bolt (straight) is better, but from what I've seen they both are about equal in capability in power handling. If your worried, take yout 2 bolt block, get a set of splayed caps and it will be better than a normal 4 bolt. BW
Old Apr 21, 2004 | 05:39 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I agree, if you want to build the strongest motor you can, get a two bolt and have it drilled for the 4 bolt splayed main caps. If you already have the two bolt main block and REALLY want a 4 bolt, just do that.
Old Apr 21, 2004 | 05:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The stock TPI set-up will be your biggest restriction. It hates high end power. Upgrading to an LT1 intake or a stealth ram does amazing things to that motor.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
