Upper Plenum Gaskets
Old Apr 22, 2004 | 02:03 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Are these required to be replaced whenever you bust open the upper plenum?
I had to drill and tap a 3/8" into a 7/16" on my thermo housing so I had to unbolt the plenum.
I also noticed that on both types of fuel pressure regulators that Summit sells for my car include the gaskets......
My car has been running on and off since the unbolting. I also noticed that the plenum bolts bottomed out before becomming tight. My bro sez vacum leak.
Too many indications of a flat gasket perhaps ?
Old Apr 23, 2004 | 08:59 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I would replace the busted gaskets.
I have taken my plenum setup apart many times and I have always put new gaskets on.
If you do not, the gasket reused may be uneven/torn/etc and will not provide a good seal. This could result in a vacuum leak, which means you will have to take the whole thing apart again to fix it.
I believe your local Autozone (or other parts dealer) sells a kit of just the upper gaskets.
Hope this helps.
Old Apr 25, 2004 | 01:39 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
gasket question
u diffenately need to replace the gasket i didnt before and my car had hell of problems idleing up and down never would idle right. and as for just buying the upper plenum gasket i work at oreillys and we sell it for less than then 10 bucks for the good fel-pro gasket.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
