Purchased TPI set-up...did I get a good deal??
Old Apr 25, 2004 | 08:53 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Purchased a complete TPI set up for $350. Only problem I have is I was promised a TPI with dent and ding free runners, and that's not what I recieved, trying to get it resolved right now!! TPI is off a 91' Camaro 305 speed density. Has intake with all intake mounted sensors, harness, coil, distributor, and computer with chip.
Old Apr 25, 2004 | 09:39 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You paid about 10 bucks per ft/lb of torque you'll get.
For a complete factory setup you did okay.
Even if you choose to upgrade the base and runners, you have all the basics needed for the job.
Old Apr 25, 2004 | 10:27 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Not a bad deal if you indeed have everything to make use of it.
How bad are the runners? Use it as an excuse to get cast ones so you can port them. Sell your stock ones off for some rebate.
Old Apr 25, 2004 | 11:40 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
$350 for a speed density TPI system with harness is a steal. Everybody and their grandmothers want that SD harness/ecm combo.
Old Apr 25, 2004 | 05:14 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
I paid $300 for a complete TA with a fairly recently rebuilt 305 and tranny. The body was pretty rusted, but everything was there. The electronics are bad and all, but I'm replacing EVERYTHING electronical for the motor when I do the swap in my Caprice.
but yes, I feel you got a pretty good deal. I would have paid that much if I didn't find my TA. What are your plans for it?
Old Apr 25, 2004 | 06:02 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
plan on swaping out my TBI for this TPI with heads and cam. Or I was told that it would work with the heads and cam I have now on my TBI motor both stock this way I can have it set up with fuel pump in tank and wiring harness ran and wait till I can afford a 350. What do you guys think??
Old Apr 26, 2004 | 12:02 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
anyone
Old Apr 26, 2004 | 12:17 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Only thing I can see is you're gonna need some new injectors and some computer tuning if you plan on using the same TPI setup on a 350. Looks like a good deal! You could polish and port it a little bit if you wanted since it's all off right now.
Old Apr 26, 2004 | 01:40 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Right. I just want to get it in now. so that when I do get a 350 the installation will go a lot smoother. I would like to try polishing the intake myself. I'm going to go take it down to get bead blasted hear in a little bit.
Old Apr 26, 2004 | 01:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It will work on your current engine without changing heads/cam, etc.
You will need to upgrade the fuel pump, the TBI pump will not give you enough pressure.
If you plan on doing heads and cam at the same time, think seriously about a new baseplate and runners too...this way you only do it once.
Then again, it's a bigg-ish project, you may want to do the TPI swap first and work out the kinks, then consider your heads and cam at a later date.
Old Apr 26, 2004 | 02:28 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I don't know if I agree with that. If you already have the intake and everything off it is a perfect time to do the heads. You're not going to want to pull that TPI unit off again to put the heads on. Just my opinion.
Old Apr 26, 2004 | 03:25 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
this is what I would prefer to do. I would rather replace my TBI with the TPI and keep it stock... base, runners, heads, cam, etc.. This way I can get it in work out any problems should there be any then wait till I can afford a 350 built the way I want it and put that in place of the 305, replace the injectors, chip and then I figure I should be all set. I would rather not waste money on heads and a cam for my 305 since I plan on putting in a 350. And since you guys say the TPI will work on my stock 305 TBI I think I'll just swap them. I know there won't be much of a gain in horse power but like I said I just want to get a head start on the 350.
Old Apr 26, 2004 | 05:53 PM
wako29's Avatar
that is a very good plan that you have:
1) put in the TPI, get the bugs worked out of that
2) get a 350 built, put that in there, get the bugs worked out of that
3) have a very nice car when complete:hail:
Old Apr 26, 2004 | 09:04 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
will the chip that I have for the TPI which came out of a 305 work with my 305 with TBI heads and cam??
Old Apr 26, 2004 | 09:07 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
got parts cleaned and bead blasted today!!
Attached Thumbnails Purchased TPI set-up...did I get a good deal??-tpi-clean.jpg
Old Apr 26, 2004 | 09:09 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
still trying to get compensated for those banged up runners. How anyone could list those as dent and ding free is beyond me!!
Old Apr 27, 2004 | 01:06 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Those actually aren't too banged up, but it was just plain stupid to say they were ding free. I would have just not commented on their condition unless asked as long as it was clearly visible in the pic. You might want to check into getting them straigntend out. I hear they can run some ***** or something through them to take the dents out.
Old Apr 27, 2004 | 09:01 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
yeah I'm going to look into how much that will cost me.
Old Apr 27, 2004 | 10:25 AM
Engine: 383 SBC
Looks nice!
Like I said earlier you might think about doing a little porting work to it. If you smooth out the taper on for the enterance and exit off the runners and the enterance to the lower intake that opens it up a little bit. The GM design kind of makes a bottle neck taper on each one. Which in my opinion is kind of stupid since the gasket goes out to the edges but that's what you get from mass production items. Doing that mod should go pretty fast. If you wanted to go further you could redo a little bit of both upper and lowers.
Old Apr 27, 2004 | 10:02 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
I wouldn't complain too much about a couple of cosmetic dimples. Those look great compared to most and for $350 bucks. Usually a complete unit with all electronics and harness can be over a $1000. By the way, you better put a high temp coating on that baby quick before it starts to oxidize.
Old Apr 28, 2004 | 02:12 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
cosmetics is a concern of mine since I plan on polishing it. But it's not worth my time to polish a set of beat up runners. What's the point!? And units that usually cost over 1000 bucks are show units that come chromed or polished with all new GM sensors, new wiring harness, new comp, and usually have custom runners. You would be a fool to pay that much for a used TPI. My
point is I was told they would be dent and ding free and that's what I expect. A good deal ceases to be a good deal when you don't get what you pay for. And I believe they were in perfect condition prior to shipping but wound up like they are because of the sellers poor packing job. The bottom of the box was falling out and the TPI was put on the bottom of the box with no padding under it and some shredded paper was thrown over the top. That's just plain lazy. I watched the UPS man almost drop it as he was bringing it up to my door and when he set the box down I could hear a loud thud....that was the sound of the unpadded TPI hiting the ground. Who knows how many other people droped the box along the way!!
Old Apr 28, 2004 | 12:44 PM
Engine: 383 SBC
Was insurance purchased through UPS. If it was I would call up UPS and tell them about it. Course the best ususally do is just find you a replacement.
Old Apr 29, 2004 | 01:29 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
damn im getting a tpi motor and trans for $300. Guy doesnt know what he did with the harness though, hes gonna look for it.
If he cant find it im going carb. The damn harness is too much!
Old Apr 29, 2004 | 04:09 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
damn all that money your saving I think you could put torwards a used harness
Old Apr 29, 2004 | 08:59 AM
1991 RS 305's Avatar
Those dents don't look too bad. FWIW, guys will sometimes work from inside the runner with a broom handle/wooden dowel with a rounded end. With care, you could "carefully" work it around the dinged area... reducing the dings, if not remove completely. They are very thin.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Sanjay
Aug 12, 2015 03:41 PM
