swapping from 87 tpi to sd ?
Old Apr 26, 2004 | 12:17 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i have put a tpi out of a 87 roc in my 91 bird, and i replaced everything, including the computer.
if i wanted to convert it to speed density at some point what would i need to get, just a wiring harness and have a chip burned for my 91 computer, my car was tbi before, but i hsould be able to just get a chip right ?
also is my airbag still functional with the 87 computer ? or is that not even connected to that?
with teh speed density i can do away with the maf, and egr right ?
what probelms should/will i run into and any suggestions ?
who do you guys recoment i talk to, in order to burn a chip, who knows what they are doing ?
Old Apr 27, 2004 | 02:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
The alternatives...
808-code route (rare)
ECM730 route read here http://www.eecis.udel.edu/~davis/z28/
for more info Do a search at DIY-PROM board you will find alot..
/N.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
