Another Ford Injector Question...
Old Apr 28, 2004 | 02:28 PM
92GTA's Avatar
I'm going to buy a set of the Ford injectors from Summit but I had a quick questions I couldn't find an answer to by searching.
Factory GM LB9 injectors are 19# @ 43.5 psi
Ford injectors 19# are rated @ 39psi
I'd like to get a larger injector than what I need right now because on plan on aftermarket heads, cam, TPI base, etc soon so I will need more fuel when I install those parts.
Do you think I should get the Ford 19# injectors and when I upgrade increase the psi or should I get the 24# for injectors and run low psi now then their rated 39psi when I do the mods?
What do you guys think? I don't want to have to buy larger injectors again and I don't want to over pressure them either to make them work. On the other hand though I don't want my current setup, which does have some mods, to run too rich right now.
I'm thinking the 19# running low pressure for now then just upping the pressure and using a custom chip later, does that sound right?
P.S. I plan on doing a custom PROM but not until I do my next round of mods because I don't have the equipment for it right now.
Old Apr 30, 2004 | 07:41 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Another Ford Injector Question...
You need to learn how to do the chip burning first. It's much easier to start learning with a stock engine, rather then trying to figure out what your doing with an engine that already has changes done to it. With a stocker if you miss the tune or make a mistake you can pop the stock chip back in and at least drive the car while you figure things out. Goes with learning to walk before trying to run.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
