Problem with Computer?
Old Apr 30, 2004 | 11:24 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I have an 85 Iroc with a 305 TPI Bored .30 with a mild cam miled heads and oversized valves. Stock manifolds with 3" cat back. I run only 3 pulleys, Crank, Water pump, alternator. Well I can't seem to figure out why I keep triping a code thats says I have a bad MAP sensor. I can't find a map sensor on my car. They guy I bought the car from did most of the work but left it like crap. The computer is bone stock but has a hypertech prom chip in it that the guy I think got second hand. Any ideas what the hell is the problem??? It dynoed 200 hp and 263 FPT the other day.
Old Apr 30, 2004 | 01:27 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
You have the crappy '85 ECM like I do. It throws a false code 34. Do a search for "False Code". There is a good thread on the DIY board that explains everything.
Old Apr 30, 2004 | 02:13 PM
Morley's Avatar
False code 34 comes from the stock PROM chips, the hypercrap one shouldn't be throwing a false code, it may in fact have a MAF problem.
Old May 1, 2004 | 06:03 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
You're right. I got ahead of myself and missed that it had the hypercrap chip.
z28addict8490
Sep 5, 2015 03:56 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
perZ
Aug 15, 2015 01:17 PM
