dead cylinder
Old May 2, 2004 | 10:46 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
dead cylinder
i have checked everything it has good vaccum good compression and good spark. my injectors have pulse. and with a stethascope they are ticking what could cause my car to missfire besides all of the things listed. the only thing i can think of is the fuel injector being clogged so no fuel is going into the ccylinder because the plug is white so it has to be too much air or not enough fuel. what should i try next?????
Old May 3, 2004 | 12:46 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Try moving your injectors around? Sounds like you're not getting fuel if you are for sure getting spark. Are you sure all your plug wires are alright, none burnt or anything?
Old May 3, 2004 | 10:35 PM
Engine: LO3 and LT1
i finally fixed the problem i used our fuel sysatem cleaner at school today. its really kind of cool you disconnect the fuel lines and run the fuel pump in a circle and connect the fuel rail to the machine and force fuel and detergent through the rail for about ten minutes then you use the machine as a fuel pump to run the detergent through the injectors to clean them while the engine is runnin. turns out i must have had alot of gummed up fuel in the fuel rail. the fuel that came out of the fuel rail was black and sludgy. now the car runs like new
Old May 5, 2004 | 03:38 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
RedBird,
I'm having the same problem as you. Everything checks out, but the car runs like crap and is missing. Is there a way I can get a hold of a fuel system cleaner like the one you used? Do you think Murrays, Lee Auto Parts, etc would carry such an item? Thanks
Old May 5, 2004 | 09:16 PM
Engine: LO3 and LT1
it is a big commercial machine i would lean more toward like a nice repair shop or even maybe a dealership.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
