code 33????
Old May 4, 2004 | 01:26 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
code 33????
my car is really starting to get on my nerves. first a few months ago it started to chug all the time below 2,000 rpm if i tried to hold it at a steady speed and also it would idle rough like need a tune up really bad. also every once in awile i would start it up and it run bad and the ses light would come on then i would turn the car off. then back on and the ses would still be on after a couple on offs it would quit and do it again a couple of months later but i would never check to see what code it was. all the time it was doing this it was running richer and richer by the day so i thought that my injectors were leaking or getting stuck cuz of how rich it was so i bought new 24# ford racing injectors and it made it run alot better and then it went back to really rich again. and started going up and down idleing so i changed then tps and set it to .50 and that didnt fix it. then about a week ago the ses light would come on and stay on and it would start running really bad with the light on so i checked it and it said code 33. i gigled the connector going to the maf and reseted the comp and it quit and then came back a couple of days later so then i bought an iac valve, maf, and a new o2 sensor and it ran like a champ for a day and now it is throwing code 33 again and running bad i dont know what it can be.
Old May 4, 2004 | 05:05 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
have u discconnected ur battery/reset the computer since ur new install?
Old May 4, 2004 | 12:25 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
code 33
yes i have
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
