High flo intake and missing plate
Old May 5, 2004 | 03:27 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I searched all over the board for the answer. Any ways, last summer I put an edelbrock high flow lower intake on my car and I didn't put the plate from the underside of my stock intake on the Hi flow. What is the purpose of this plate and could it cause any problems? Thank you.
Old May 6, 2004 | 08:29 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I did the exact same thing as you. I installed my edelbrock high-flo intake and Super Ram before I realized my mistake. I Decided not to remove everything to fix my F**kup. I havent had any problems at all. The cars running great. When I rebuild my motor I'll install it then.
I'm almost positive that the part your talking about is a splash shield to keep the hot oil off the bottom of the intake base. I'm assuming this would help keep the air flowing throw the intake cool to help performance. Anyway I have seen no ill effects and I'm sure you'll be fine too. Just keep the part around and install it next time you have the fuel injection off............. Eric
Old May 7, 2004 | 12:48 AM
irocman7's Avatar
Engine: Forged 383
thats the one, someone told me it was to keep the oil off. The frustrating thing is that i didn't get ANY gains from the intake and SLP runners. Could it be bacause the intake is heating up the cool air coming in?
Old May 8, 2004 | 10:56 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I doubt that is the reason for your lack of gains from your mods. The egr passage also runs through your intake and is a LOT hotter than the oil that may be splashed up onto the bottom of you intake.
JM.02,
Charlie
Irocman7,
I see you are from Kansas. Are you on the KSFBA message board?
WWW.ksfba.org/forums
Old May 8, 2004 | 11:44 AM
Car: 89 Formula 350
JM.02,
Charlie
Irocman7,
I totally agree with the above statement. It not going to be hurting you
Old May 10, 2004 | 03:17 PM
irocman7's Avatar
Engine: Forged 383
Irocman7,
I am checking it out now.
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
1985chevydude
Aug 20, 2015 12:29 AM
