305 TPI cam
Old May 6, 2004 | 08:29 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
305 TPI cam
I have a 1986 Trans Am with 24 Lbs injectors and a 3.73 9-bolt rear end. The cam that GM put in there 1986 305's suck, and i wanted to get one with bigger lift. I also wanted the motor to cam to a point where you could tell for sure that i had a cam. If the cam is too big will I need a new chip, or computer, and how big is to big. So my question is what cam would fit my needs? All so get me out of the hole faster
Thank you
Old May 6, 2004 | 10:40 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
What other mods have been done to the car? If this is an auto does it have the stock converter? You may want to call CompCams and they can give you a good recommendation based on you mods.
Old May 7, 2004 | 06:47 AM
Car: Trans Am
yea is an auto with a 2400 stall, rebuilt trans with shift kit. SLP runners ported to match the runners, I'll call CompCams to see waht they say thanks
Old May 7, 2004 | 12:47 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
IIRC that is a flat-tappet motor so the 218/228 114 LSA would be good.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
