Porting 305 tpi, too many custom gasket sets here to choose from, help!
Old May 7, 2004 | 09:59 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I have to replace my intake manifold gasket and figure I will port my stock TPI setup and 305 as much as I can while I have the intake off. There are different gasket sets listed at advanced auto but Im confused as to what one to buy. I guess I could always go with stock and make the gasket openings bigger to fit my porting job but it looks like some of these sets are already made for biger ports. Can anyone make sense of this? I just want the best set that will seal up my stock runners and intake manifold after I do some major porting. Do I need or want the exhaust crossover blocking shields on the gaskets??
COPIED FROM PARTS STORE WEBSITE
Fel Pro MS930351
Upper Set Included Find in a store Ships in 1 day
Weight: 0.8 lbs. $25.88
Fel Pro MS93160
Upper Set Ships in 1 day
Weight: 0.8 lbs. $10.88
Felpro High Perf. 1206
Intake Manifold Set: Perf.; 1.34 x 2.21 Port Size; .120 in. Thickness; Medium Race Port; High Density rubber-fiber sheet w/Printoseal; On Brodix-use w/8; 10; 11; 11X; Alum. or Cast iron Heads with Conven. port & Bolt location; No exhaust crossover or blocking shields; Small Chev. Ships in 1 day
Weight: 2 lbs. $19.88
Felpro High Perf. 1296
Intake Manifold Set: Perf.; 1.60 x 2.00 Port Size; .060 in. Thickness; Chev. Splayed Valve; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.3 lbs. $19.88
Felpro High Perf. 12374
Intake Manifold Set: Perf.; 1.40 x 1.90 Port Size; .090 in. Thickness; Chev. SB2 Mirror Port; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.4 lbs. $23.99
Felpro High Perf. 1244
Intake Manifold Set: Perf.; 1.25 x 1.90 to 1.40 x 2.30 Port Size; .060 in. Thickness; Trim to Fit; High Density rubber-fiber sheet w/Printoseal; Alum. or Cast iron Heads with Conven. port & Bolt location; Contains cutout for Brodix water fitting; No exhaust crossover or block
1 Year Limited Warranty Ships in 1 day
Weight: 2.5 lbs. $16.88
Felpro High Perf. 1278
Intake Manifold Set: Perf.; 1.25 x 2.15 Port Size; .045 in. Thickness; Chev. 18 deg. High port; High Density rubber-fiber sheet w/o coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.4 lbs. $21.99
Felpro High Perf. 12373
Intake Manifold Set: Perf.; 1.40 x 1.90 Port Size; .060 in. Thickness; Chev. SB2 Mirror Port; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.6 lbs. $21.99
Felpro High Perf. 12372
Intake Manifold Set: Perf.; 1.40 x 1.90 Port Size; .045 in. Thickness; Chev. SB2 Mirror Port; High Density rubber-fiber sheet w/o coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.1 lbs. $21.99
Felpro High Perf. 1288
Intake Manifold Set: Perf.; 1.25 x 2.15 Port Size; .120 in. Thickness; Chev. 18 deg. High port; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.6 lbs. $23.99
Felpro High Perf. 1267
Intake Manifold Set: Perf.; 1.38 x 2.28 Port Size; .120 in. Thickness; Large Race Port; High Density rubber-fiber sheet w/Coating; On Brodix-use w/12SP-S; Alum. or Cast iron Heads with Conven. port & Bolt location; Contains cutout for Brodix water fitting; No exhaust crossove Ships in 1 day
Weight: 0.5 lbs. $22.28
Felpro High Perf. 1283
Intake Manifold Set: Perf.; 1.25 x 2.15 Port Size; .090 in. Thickness; Chev. 18 deg. High port; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.5 lbs. $23.99
Felpro High Perf. 12375
Intake Manifold Set: Perf.; 1.40 x 1.90 Port Size; .120 in. Thickness; Chev. SB2 Mirror Port; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.3 lbs. $23.99
Felpro High Perf. 1263
Intake Manifold Set: Perf.; 1.31 x 2.02 Port Size; .060 in. Thickness; Raised runner Chev. & Pont. "867" Head; High Density rubber-fiber sheet w/coating; Contains cutout for Brodix water fitting; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.4 lbs. $19.48
Felpro High Perf. 1282
Intake Manifold Set: Perf.; 1.25 x 2.15 Port Size; .060 in. Thickness; Chev. 18 deg. High port; High Density rubber-fiber sheet w/coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.5 lbs. $21.99
Felpro High Perf. 12371
Intake Manifold Set: Perf.; 1.40 x 1.90 Port Size; .030 in. Thickness; Chev. SB2 Mirror Port; High Density rubber-fiber sheet w/o coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.3 lbs. $21.99
Felpro High Perf. 1207
Intake Manifold Set: Perf.; 1.38 x 2.28 Port Size; .060 in. Thickness; Large Race Port; High Density rubber-fiber sheet w/Printoseal; On Brodix-use w/12SP-S; Alum. or Cast iron Heads with Conven. port & Bolt location; Contains cutout for Brodix water fitting; No exhaust cross
Weight: 2.5 lbs. $19.98
Felpro High Perf. 1277
Intake Manifold Set: Perf.; 1.25 x 2.15 Port Size; .030 in. Thickness; Chev. 18 deg. High port; High Density rubber-fiber sheet w/o coating; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Felpro High Perf. 1259
Intake Manifold Set: Perf.; 1.38 x 1.85 to 1.66 x 3.03 Port Size; .060 in. Thickness; Buick/Dart-Trim to Fit; High Density rubber-fiber sheet w/Printoseal; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.5 lbs. $28.99
Felpro High Perf. 1245
Intake Manifold Set: Perf.; 1.25 x 1.90 to 1.40 x 2.30 Port Size; .120 in. Thickness; Trim to Fit; High Density rubber-fiber sheet w/coating; Alum. or Cast iron Heads with Conven. port & Bolt location; No exhaust crossover or blocking shields; Small Chev. Listing Ships in 1 day
Weight: 0.5 lbs. $24.88
Old May 7, 2004 | 10:09 PM
87350IROC's Avatar
Car: 87' IROC
are you actually taking the manifold off or just the runners and plenum? you can't really do much to stock runners to necessiate larger gaskets. most of the gaskets you have listed are for the manifold to head seal.
Old May 7, 2004 | 10:43 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Thats what I was wondering, only the first 2 mention an upper set. I want to port the plenum, runners, intake manifold and the entry to the heads to the max. I want a set of tpi gaskets that will give me enough room to do this, will the stock gaskets have enough extra material for this? And whats the deal with the manifold gaskets that dont have exhaust crossover blocking shields on the gaskets?? What do those shield thingies do anyway?
Old May 10, 2004 | 01:56 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I don't think it would be a good idea to port the opening to the heads while its on the car, your going to get metal shavings inside your motor.
Old May 11, 2004 | 01:47 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
yeah, there is no safe way to port match the heads while they are on the car, ill have to skip that part.
BlueIroc-Z
Jun 9, 2019 03:22 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
