Which coil/wires to get? Are these the correct part numbers?
Old May 10, 2004 | 10:51 AM
Dr G's Avatar
I'd like to get a new coil and wires for my 1989 350TPI GTA.
Is this the coil to get? MSD Blaster GM Coil
http://store.summitracing.com/defaul...&part=msd31839
Do I need to get this MSD-8876 - MSD to GM Dual Connector Coil, late model harness?
[url]http://store.summitracing.com/default.asp?target=search.asp&type=bysummitpart&searchtype=both&part=MSD8876
Old May 10, 2004 | 10:59 AM
Dr G's Avatar
Are these the correct wires? MSD-31839.
It says on Summit they are for:- 1988-92 305 (5.0L) Camaro, 1988-90 305 (5.0L) .... with remote mount HEI, custom fit, 8.5 mm, helical wound core, silicone jacket, Super Conductor wire set. But does not mention the 350ci cars.
Many thanks for all the help!
Old May 10, 2004 | 03:08 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
The wires will work just fine. Makes no difference if it's 305 or 350.
Old May 11, 2004 | 08:51 PM
Dr G's Avatar
Thanks Rob. It seems that the links etc in my post got a bit missed up when I had edited it. I'll sort them later on.
Which coil do you think I should get? Do you have a Summit part number for it?
Many thanks!
Old May 11, 2004 | 09:10 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
That's the correct replacement coil from MSD. But I doubt you'd need the harness unless yours is fried.
As for wires, those are also correct. But that part number's for red wires. Is that what you want? You can also get the same set in black, if that's more preferable to you. That's part number 31833.
Good choices.
Old May 12, 2004 | 04:43 AM
Dr G's Avatar
Thanks LAFireboyd!
Old May 12, 2004 | 08:11 AM
formul8!!'s Avatar
Car: 2004 GTO
I have been using both for years now- no problems. The MSD wires even come with neat little numbered plastic clip-ons for the wires to mark the firing order.
Old May 12, 2004 | 01:25 PM
dakleenupman's Avatar
Car: 2000 Astro
Engine: 4.3L of funk
Re: Which coil/wires to get? Are these the correct part numbers?
The 8876 harness is to be used in conjunction with the MSD A series of ignition amplifiers. The harness plugs into the 6A box and your stock or replacement coil eliminating the need for splicing..........
Later,
Chris
Old Jan 29, 2009 | 09:55 AM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Old topic but what the hell..
I bought MSD-31839 and they are to short!
Theres no way to have them not touching the stock exhaust manifolds.. I wrapped them with some heat shield but hey - If I buy a plug wires it would be nice to have them a bit longer so I wouldnt have to strech them :-P
Old Aug 17, 2009 | 06:58 PM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
yeah this is old and yeah thes are short wires maybe i got some mixed up but i don't think so
Old Aug 18, 2009 | 04:39 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I'd just go for the kit that you cut them to length an make them up youself. That is the best way to avoid them being too short or long.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
