Modifying TPI intake bolt hole....
Old May 10, 2004 | 01:03 PM
kaylin4u's Avatar
I have a set of Dart Pro 1 aluminum heads for my 355 build and having to use a dremel with a cutting tool to modifiy the two center bolt holes on my TPI lower intake. Just wanted to know if anyone else has done this and been successful? Thanks.
Old May 10, 2004 | 02:23 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I actually had a machine shop do it, but it's a standard procedure to have to do it to get it to mount on pre-1985 style heads. Works fine!
- Vern
Old May 18, 2004 | 06:55 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
i have an 86 surburban 350 and have the 88 tpi on top. can show you some close ups if you like.
Old May 19, 2004 | 08:29 AM
kaylin4u's Avatar
Thanks. I took my dremel and cutting bit to oval out the hole. I just installed the intake and looks good so far.
If you want, go ahead and post the pics. I'd like to see if I did mine right.
Old May 21, 2004 | 11:08 PM
onebinky's Avatar
yep, as long as you don't go way oversize on the holes, you won't have any issues with the manifold sealing up to the heads. There's plenty of mating surface on both sides of the hole, at least an inch both ways IIRC.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
