injectors
Old May 12, 2004 | 11:42 AM
ajm_shorty's Avatar
injectors
How can i check my injectors to make sure there firing?
I checked the fuel pressure VIA shrader valve on fuel rail and i got about 45 PSI
My 350 TPI is still not running and im not sure if the injectors are firing
Old May 13, 2004 | 12:40 AM
onebinky's Avatar
Plugging a noid light into the injector harness will tell you if the quad driver in the ECM is firing the injectors. You can pick up a decent one at the local parts house for +/- $20. You do NOT want to use a regular test light though, it'll fry the driver in a heartbeat and then you really will have issues with the injectors
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
