Stock PROM for 305 TPI, auto & 3.73's?
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
I tried a search on this in the PROM listings but the best I could find was for 3.27 rear gears. Will it need a custom burned one?
It's an '88 TPI setup.
Thanks,
Larry.
Thanks,
Larry.
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Larry, I used a very similar chip in my car for a few years until I converted to stick. The only thing that is really affected is when it goes into lockup, and that is controlled by MPH, not gear ratio. Don't worry about a custom chip.
Car: 1988 Monte SS
Originally posted by Insomniac92z28
The PCM does not calibrate the speedo on the 700r4s, but maybe the 200r4s are different???
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Steve,
Thanks. The main thing I was concerned with was any "less" performance with a chip that was for a different rear gear ratio. How was the performance when you had the 2004R?
I know you like the T5 better, but I've decided to wait awhile on doing one. The TPI setup I found (if I get it
) is from an '88 Corvette that had no more than 3.08 gears.
Larry.
) is from an '88 Corvette that had no more than 3.08 gears.Larry.
