Finally some 1/4 times! Whatcha think?
Old May 16, 2004 | 09:57 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Well I finally made it to a 1/4 mile track to see what all my work did for me. Before my best was 15.4 ...
Today was 14.23 at 97......good? That equates to more than what my dyno was at 224.....so Im thinking I have more than that...you think? The charts say Im in the 245 range..does that sound right?
Check out my dial in....I made it to the T! but lost it on my crappy R/T......PRO TREE SUCKS! I couldnt get the hang of it...I even went and tried to protest it but no chance so I bought back in and lost again on my R/T....My 60's stayed consistent all day in the 2.0 range. How in the hell are you guys getting sub 2 sec 60's on street tires and stock verters? I wasnt spinning at all that I could tell...
My 1/8th times were even better than my best at the local track of 9.299
Whatcha think about my timeslip....anything I can do to cut some more off the times? Do you think runners? MSD box...what? Im open for some ideas....
thanks guys!
Attached Thumbnails Finally some 1/4 times! Whatcha think?-dsc01173.jpg
Old May 16, 2004 | 10:00 PM
PhilM's Avatar
Car: Accepting applications...
that's a shame to run dead on and get beat by someone who is 2 tenths off...practice practice practice practice practice practice...
and practice some more...
not a TPI expert but an MSD is always a worthy investment
Old May 16, 2004 | 10:32 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Good job man. You're only a torque converter away from 13's.
Old May 16, 2004 | 10:55 PM
Brent's Avatar
One nice example
Old May 17, 2004 | 01:51 PM
what about some type of bolt-on?
Old May 17, 2004 | 09:22 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A TC is a bolt on. It'll be the best bang for the buck - 2 or 3 tenths off your ET.
Old May 17, 2004 | 09:55 PM
yeah I know I can get 2 to 3 or more with a TC...but what about other bolt ons?
Old May 18, 2004 | 02:08 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Well uh... u/d pulleys work well, when they are done correctly.
ALso, some SLP runners cleaned up a little with a ported stock base will work well too.
Old May 18, 2004 | 10:39 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Good times man!!
I would have to agree that a torque converter would do wonders.
I have a Coan converter and my fiancee had a Vigilante and mine is just as good if not better than heres. (1.59 on Nitto 245/50r16 NA)
What does your exhaust consist of again?
Also bolt on a NX kit and go mid 12's ALL day
Chris
Old May 18, 2004 | 10:50 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
unbolt the front sway bar, bolt in some LCA's. help xfer weight and plant.
what tires are you running? stock? what pressure? try lowering the pressure a bit too.
Old May 18, 2004 | 10:55 AM
my exhaust is....SLP headers going to the SLP yipipe going to a 3" pipe where my CAT used to be and then from there is the factory 2 3/4" pipe...I think...and then to a Flowmaster.
Im running 26" Dayton street tires set at 24lbs. I dont get but a little chirp when leaving the line.
Old May 18, 2004 | 01:51 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Base and runners, would be a next good mod for you. I also agree with the tq converter. Those are great times for a 305 with bolt ons
Old May 18, 2004 | 02:47 PM
But I heard that aftermarket or even just ported base and/or runners would take away what lowend I have. It doesnt feel like I got alot now so I wouldnt want to loose anymore....
If putting some SLP runners would help then I wuld do that and then look for an aftermarket or ported/polished intake.
what do you think?
Old May 18, 2004 | 03:34 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Intake and runners. I have aftermarket intake/runners on my 305 and I did lose some low end, but then it does rev to over 5000rpm at the other end. It pulls well. I'll hopefully have the dyno numbers and track times for my combo this year.
Robert
Old May 18, 2004 | 03:39 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
It may move your power band slightly but it can only help your overall performance to get more air into the cylinders. Breath in breath out, increase the ability for your engine to do either will improve performance.
Old May 18, 2004 | 03:44 PM
When I dynoed the car I was still at 8* in timing and forgot to take the screens where the fog lights used to be...and I dyno'ed at 224....
So now I have it set to 10* and always remove my screens when I drag....
WHen I punch in my weight 3475/w me and my times, they come up with 249hp and 311tq..........is that correct or are the charts off a bit?
Old May 18, 2004 | 03:58 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Those types of calculations can only give you a rough estimate. To many factors besides weight and hp combine to give you your actual 1/4 times. I don't think 2* difference in base timing and screens will affect your dyno results to much.
Old May 23, 2004 | 03:48 PM
nick418's Avatar
Engine: L98, Hemi 6.2
sweet
Old May 23, 2004 | 07:37 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Correct, and you can get the torque converter based off your new power band. So if the torque peak moves up then just get a bigger convertor.
Old May 27, 2004 | 12:29 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Lower control arms and relocation brackets. You'll definately need the LCARBs because your car is lowered.
I cut a consistant 1.9xs on cheapie 245/50/16 Kumho 711s with LCAs and a converter.
Old May 27, 2004 | 05:03 PM
yeah I was thinking about getting a set of LCA and some BMR relocation brackets. Im not getting any wheel spin though and I thought that lowered cars get wheel spin bad...but not me. That might be cause I lower my tier pressure all the way down to 25lbs. So do the RB's help in the transfer of the weight?
Old May 28, 2004 | 10:52 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
I gotta agree with the people saying converter. I know I'm giving results from a LS1 but my Midwest 3200 dropped an easy 3-4 tenths off my time and 2+tenths off my 60ft time. Mph might have dropped maybe 1-2 but it's well worth it imo and is completly streetable
Or even with a flowmaster, a cutout might give you a little gain. I picked up .15 sec over a closed exhaust on my TA and even if it only gives you .1 or .05 for 30 bucks it's worth it.
Old May 28, 2004 | 03:08 PM
mikobu3's Avatar
wishmaster97
not sure if you ported and polished your heads add some 1.94 intake valves new springs , you will see another 35 hp , also get a 3 angle valve job done
good times
Old May 28, 2004 | 03:26 PM
vwdave's Avatar
Its only a 305, I doubt he would notice THAT much of a difference with ported heads.
I would suggest a converter. I have a corvette unit in mine and the car has a freaknasty launch compaired to before.
Old May 30, 2004 | 07:18 AM
mikobu3's Avatar
vwdave
don;t notice anything with ported heads ,
thats got to be the stupist thing i heard on here, thats how you get a 305 in the 300 hp area brother , matching a good cam to better heads makes the power
like i said before , there are way to many kids on this forum , post correct info next time
Old May 30, 2004 | 07:23 AM
vwdave's Avatar
Originally posted by mikobu3
vwdave
I didnt say "you wont notice anything." I meant you probably would not get 35hp from ported stock heads on a mostly stock 305. 15hp I could understand, but not 35. Unless you can provide proof otherwise (dyno or flowbench data), I will continue not to believe it. Please stop trying to talk down to me. I might just know a thing or two.
Old May 31, 2004 | 08:09 PM
mikobu3's Avatar
20 hp porting and polishing and another 10-15 with bigger 1.94 intake valves and better springs
Old May 31, 2004 | 08:40 PM
wishmaster97
good times
actually your not the only one to tell me that. I talked to a guy when I was looking for a place to get my exhaust put on and he asked if I had my heads ported when I did the cam, I told him no and he said I was freakin crazy for not doing that since I was right there at them. He even said that I could have gained another easy 35HP from doing that. He knows a guys that would only charge me $175 to port them and do the angle job thingy...I have no idea what thats all about but he did mention the angle job thing and sizes. I may if I feel like tearing back into the motor do that when the winter time comes and I will also yank out the LT1 and put something in there better. Which I should have done in the first place but, LIVE AND LEARN!
Old Jun 1, 2004 | 11:22 AM
mikobu3's Avatar
wishmaster
i recently put in a comp xe 212 218 449 456 112lsa cam and there kit ,
ported and polished the 416 heads with bigger 1.94 intake valves , new comp springs, retainers, 3 angle valve job ,
dynomax headers , with a crappy y-pipe , 3.42 gears and only 20 000 original miles on the 86 305 tpi ,, oh yeh i ported the base
still using the stock fuel pressure , timing is not correct , i think the iac is not set up , but let me tell you the car moves well ,
i need to get it tuned up properly , that 14.2 sounds great to me
evilstuie
Jan 9, 2020 08:29 PM
aaron7
Aug 17, 2016 06:02 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Polo Z03
Sep 10, 2015 06:43 PM
86IROC112
Aug 21, 2015 07:20 PM
