Ported Stock Runners or Aftermarket???
Old May 17, 2004 | 12:44 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
should i save some money and just port my stock 305 runners out or would i greatly benefit on some aftermarket high flo runners???? keep in mind this is going to be swapped on a 350 with some other decent mods attached.
Old May 17, 2004 | 12:50 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
stock runners are tubular sheet metal, so porting is a no can do
Old May 17, 2004 | 02:58 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
yep, your only option is to get aftermarket runners and port them
Old May 17, 2004 | 04:04 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well damn, that answers my question...........any suggestions on aftermarket runners?
Old May 18, 2004 | 02:09 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
There is not much difference in aftermarket runners. Any brand you can pick up for a good price on these boards or ebay is the way to go. There all basically within a MM or two of each other and that difference goes away as soon as you port and gasket match them. Although you will see a much better return on your money if you get the base as well, opening up one without the other offers little to no gain.
Old May 18, 2004 | 02:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thats what i figured...........does anyone know much about the votrec tpi setup from SDPC?? good power for the money?
Old May 18, 2004 | 02:45 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Its about $450 but you don't have vortec heads, do you? All bases are in the price range of $400-500 after shipping. The main ones to look at are Edelbrock (Summit $380), TPIS Big Mouth (made by Edelbrock $450), Acell ($425) AS&M ($?). Again as with the runners once you open the ports a hair ther all basically the same thing. I have the Edelbrock base and runners that I am porting with my plenum. I just did tons of research on which ones to buy and why. I could not find any definitive proof that one is any better or worse than another once you start taking a grinder to them so I would just get whatever you can find at the best price. You can even mix and match. You will also want the large tube runner gaskets with 1.75" opening compared to the stock 1.44"
tazs2000
Jul 15, 2017 08:44 AM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
89fast5oh
Aug 20, 2015 08:34 AM
mx127
Aug 10, 2015 08:13 AM
