Ran codes for first time..code 32 help
Old May 19, 2004 | 04:45 PM
badapple's Avatar
Car: 1987 GTA
I did my diagnostic check and got code 32. I did some research and didnt find much, something about the EGR. Can you guys explain whats going on and what the EGR is. Thanks :hail:
Old May 19, 2004 | 06:16 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
code 32
I had code 32 and I had a vacuum leak on the front plate on the TPI. A new gasket solved everything. Everybody diagnosed it as a EGR until we did a complete diagnosis and found a vacuum leak.
Old Jul 13, 2004 | 10:19 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Re: code 32
what are you referring to when you say you had a vacuum leak on the front plate of the tpi?
i deleted my egr about a month ago (computer still sees it as being there as i haven't had it tuned out of the ecm). been running fine for a month with no codes and then tonight on the way home, boom...code 32. i am lost and don't know where to begin. i know it is not a stuck valve, because there is not one there...it is a block off plate and gasket.
Old Jul 13, 2004 | 11:02 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
That reply was actually made by my father-in-law (92BlackZ)...he was just signed-in as me. He was referring to the gasket under the aluminum plate on top of the throttle body. I had bought him a billet Z28 plate for him and the gasket that came with it didn't seal properly when he installed it and resulted in a vacuum leak.
Hope that's all your problem involves...pretty simple fix if that's the case.
Old Jul 13, 2004 | 11:11 PM
White91GTA's Avatar
Engine: 5.7L TPI
i don't remember there being a gasket there when i took that plate off mine to install my airfoil. i may look into that and hope it fixes my problem.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
gta892000
Sep 16, 2015 12:37 AM
RyanJB
Sep 2, 2015 01:27 PM
