What should I run with the HSR???
Old May 23, 2004 | 08:11 PM
firefrombelow's Avatar
OK, I am planning on converting my 1991 Firebird 3.1L V6 to a L98...I see stock L98s run low 14s stock.....What should I run with just the HSR as th only mod?? Also, How does this compare to the Miniram???
Old May 23, 2004 | 08:59 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
The HSR on an L98 with no other mods will not improve the ET substantially. The lack of torque will negate the added hp.
Old May 23, 2004 | 10:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree. I think you would be better off upgrading the exhaust system first. Headers, 2 1/2 inch pipes into a 3 inch system and a good muffler. You will see good improvements right away.
Those manifold are for higher rpm. To take advantage of them you need a good exhaust system, cam and heads.
Old May 24, 2004 | 03:37 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Yes - the HSR on top of a stock L98 is a waste of time and money.
The exhaust will open up the top end potential of the TPI system a little, and the car won't lose it's great torque which in my opinion makes it more fun to drive than a lot of faster cars.
Old May 24, 2004 | 01:13 PM
Chrome's Avatar
Car: 92' RS Camaro
Bigger Cam
Better Heads
High Stall TQ
These w/ the HSR will make her scream
(Doesn't have to be AFR's - there are plenty of budget heads w/ alittle bit of porting that flow decent for the $$$)
PS I think the V6's had 3.42 gears which would be ok, but a set of 3:73 and posi might be nice w/ that V8 - one wheel peel sucks!
eightsixseven
Dec 16, 2024 01:50 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
perZ
Aug 21, 2015 05:51 PM
355tpipickup
Aug 19, 2015 10:02 PM
355tpipickup
Aug 13, 2015 07:35 AM
