Excessive fuel with 89 305 TPI
Old May 27, 2004 | 09:42 PM
nascarfool.com's Avatar
Fuel pump was replaced with a perfomance pump, adjustable FPR also installed. The pressure stays at 42psi idle and varies from 38 to 42 psi when driving. The car runs real bad and smells of gas. Other parts that were changed are the charcoal canister, pump relay, intake gasket and distributor. I'm thinking that a fuel injector or injectors have gone bad. Should the fuel rail pressure drop when the car is shut off or should it hold the pressure ? When shut off the pressure will drop to 20psi within a minute. After five minutes it will drop to zero.
Old May 27, 2004 | 09:53 PM
MasterEvilAce's Avatar
it should drop slowly over a period of time, but it should never drop below a certain point.
something is definitely wrong with your car... I have the same problem, also (although it may be fixed now, but i'm not positive...) I still have hard-starting problems, though.
Old May 27, 2004 | 10:07 PM
Thanks for the reply. Fortunately, it's not my car. I would have done had it towed off if it was mine. It's my sons car. I think the injectors are leaking.
Brcharrelson
Aug 26, 2015 07:47 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
