25lb LS1 or 30 Accell injectors I need an answer NOW
Transmission: A4
I need to know if my NEW LS1 injectors I bought from SLP will work with my engine or if I will need 30lb Accell injectors. I have heard that 25lb LS1 injectors have a different cycle or something. I dont want to have some weird fuel pressure setting because of these LS1 injectors. Someone please explain what is so diff between the LS1 injectors and the regular ones our 3rd gen cars use. engine specs are as follows:
383 10:1CR
stealth ram
holley 58MM TB
comp cams 224 230 .502 .510 LS 112
AFR 190 heads 72CC
rest of mods are in sig.
383 10:1CR
stealth ram
holley 58MM TB
AFR 190 heads 72CC
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: 25lb LS1 or 30 Accell injectors I need an answer NOW
383 10:1CR
stealth ram
holley 58MM TB
AFR 190 heads 72CC
383 10:1CR
stealth ram
holley 58MM TB
AFR 190 heads 72CC
Car: 89 IrocZ
Engine: L98-ish
SLP 1 3/4" headers with dual cat Y pipe
NO Cats. SLP loudmouth.
The SVOs are bigger than the LS1 injectors, give you more room to grow, and still blow a clean pattern a low-pulsewidth idle.
Mike Davis was able to max out the big 28# @ 58psi LS1 injectors on his 355ci engine...> 90% duty cycle. Definitely going to limit you on a 383 with pretty much the same exhaust he was running.
Originally posted by 8Mike9
Who ya asking Kevin? And why would that affect the question originally posted?
If he was running smaller headers or an otherwise more constrictive exhaust system, I'd say the LS1 injectors were fine.
But, he's evidently done some homework and picked out good parts, so I'd go with Ford red-top 30# injectors and have some room to tune.
[Sold] Accel 30# injectors
hydrolic144
Aug 29, 2015 04:14 PM
