Code 42
Old May 30, 2004 | 03:30 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Code 42
Can anyone help me figure out what is causing the code 42? For some reason, it just all of a sudden threw the code yesterday as i was getting ready to leave the track. Don't have any clue as to why. I am wondering if it is possibly because of the MSD coil that I put on. Any help would be appreciated. TIA.
John
Old Jun 2, 2004 | 10:31 PM
DON 88T/A's Avatar
A code 42 just came up on my 88 T/A....I have a check engine light,as well as the car is running in back up limp mode...scanned it the other day...the suggestions from the scanner was either a faulted est wire,bad ignition module or faulty ECM...the car starts and runs but has no power...the est wire looks good from what I can tell,and the igntion has been fine does not miss even in limp mode...so I'm replacing ECM..
Does your car run rough?
Old Jun 2, 2004 | 10:56 PM
White91GTA's Avatar
Engine: 5.7L TPI
No...my problem turned out to be that the EST wire was not completely plugged in, so it was staying in limp mode.
Old Jun 2, 2004 | 11:14 PM
DON 88T/A's Avatar
Good.....wish mine would have been that easy..
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
