Running the SuperRam upper intake (plenum/runners) with the SDPC Vortec TPI intake?
Old May 30, 2004 | 05:53 PM
WS6Formula305's Avatar
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
I'm looking at options to help the Hot Cam in my crate engine breathe more, and I was looking at the Super Ram-- but it's not drilled for the Vortec heads like the SDPC intake that came with the crate engine. According to Lingenfelter's website the plenum/runner kit bolts to the stock L98 intake, so since the SPDC intake is patterned after the stock intake, I don't see any reason why the combination wouldn't bolt up?
http://www.sdpc2000.com/cart.asp?act...1460&pid=13740
That's the link to the intake manifold I speak of, although I'm sure most everyone on here is familiar with it.
Old May 30, 2004 | 10:24 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
From what I hear, it can be done (SuperRam with SDPC base)... Some work is needed.. OMINOUS_87 would be the guy to talk to, I think he did a write up on it before (might try searching for it)..
Old May 31, 2004 | 11:49 AM
OMINOUS_87's Avatar
https://www.thirdgen.org/techbb2/sho...hlight=extrude
https://www.thirdgen.org/techbb2/sho...hreadid=236033
Old May 31, 2004 | 04:56 PM
Thanks a lot guys
Old Jun 1, 2004 | 01:38 AM
contactpatch's Avatar
Engine: sbc 350
What is the size of the runners, inside the SDPC base?
How does that compare to GM-stock, Tpis,etc?
contact
Old Jun 1, 2004 | 01:56 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Not sure, quite a bit bigger using the old reliable eyeball.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
mustangman65_79
Aug 8, 2015 12:07 PM
