Roller rockers on a comp cam
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I tried searching this and couldn't quite get the right answer.
I have a '91 gta w/305tpi. I have added a comp cam(.48 intake, .487 exhaust, 206-212 with .110 LS). Could I put on 1.6 roller rocker arms? Will it help? Will it be noticable? Or am I just wasting $350cdn?? I already have 3:42 gears, ported plenum, afpr, 8.8 wires, no cats and headers. Is there something else I could spend my $ on???
LB9GTA
LB9GTA
Car: 92 Camaro
Engine: ZZ4 350 HSR
Transmission: G-Force T5
By installing 1.6 rockers, you will increase the valve lift to roughly .512" and add a couple of degrees to the duration...I say go for it, especially if you are still using the stock stamped steel rockers.
I have the GM ones and like them very much.
Car: '91 GTA
Engine: 421sbc
You say that you have the gm ones, they make 1.6 roller rocker arms? Are they cheaper than an aftermarket? Could you tell me the diff in hp or 1/4 mile times??
LB9GTA
LB9GTA
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Here's the link to the GMPP Roller Rockers. These are the ones that come with the LT4 HOT cam kit.
http://sdpc2000.com/cart.asp?action=...d=523&pid=1610
Sorry, here's the correct link to the LT4 rocker arms....
http://sdpc2000.com/cart.asp?action=...d=523&pid=1086
Car: 92 Camaro
Engine: ZZ4 350 HSR
I had SDPC install them on the ZZ4 when I bought it, so I don't have comparison numbers...They were just under $350 for the set...try www.gmpartsdirect.com for the best possible price on them.
Car: '91 GTA
Engine: 421sbc
Kinda expensive for me in Canada, but did you see a diff? Anything documented in a track time improvement? For $350, I might as well wait for a while longer and get NOS for $900!!
LB9GTA
LB9GTA
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Are you running stock heads? If so you are right at the limit now if not over with the rockers/cam you have. You might bind the springs with the 1.6 rockers. If you have after market heads set up for a higher lift disregard this message. Allen
Car: '91 GTA
Engine: 421sbc
Dyno or track times with roller rockers
I have stock heads. So maybe the 1.6 roller rockers are not for me now!
Just out of curiosity, does anyone have dyno or track times for the difference with roller rockers???
LB9GTA
LB9GTA
Car: 92 Camaro
Engine: ZZ4 350 HSR
If the rockers are too much $$ for the ~10HP gain, then try saving for new heads - or better yet, put the cats back on the car and notice the instant low end torque you just picked up.
Car: '91 GTA
Engine: 421sbc
If I put the cats back on I would gain the low end but lose the top end, wouldn't i? Or was that a joke?
LB9GTA
LB9GTA
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
