TPI air set up for Birds
Old Jun 1, 2004 | 06:37 PM
Mr.Crackhead's Avatar
Car: 1990 Formula
Engine: 355
does any of teh birds run a air intake like the Y set up on the camaro's or can it be run?
Old Jun 1, 2004 | 06:52 PM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
you mean the dual snorkel?
Old Jun 1, 2004 | 06:53 PM
Car: 1990 Formula
Engine: 355
yes.
Old Jun 1, 2004 | 09:50 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It can be done, but it is not a swap over. You need to fab an intake where you have a much wider "Y" and the respective air filters would wind up on opposite sides of the engine compartment. One all the way front and left, and one all the way front and right.
Not worth it! Just take your time and make a free flowing single inlet CAI - it will work just as well as a dual snorkel.
Old Jun 1, 2004 | 10:31 PM
Guest
Guest
Posts: n/a
I agree that its not worth it to run 2, and the Camaro setup wont fit so dont even try that one.
Make your own. Visit Home Depot or some other box hardware store, and buy some ABS plastic pipe, elbows and couplings.
Old Jun 1, 2004 | 11:02 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I think the SLP dual air cleaner setup fit the birds.
Old Jun 2, 2004 | 07:28 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Not sure what climate you're in... I cooked PVC elbows and so did a friend of mine with an ESCORT! in the midwest summer heat. OH: Not worth the headaches of lose hose clamps all of the time on a daily driver. I even lost a $40 filter because of warping PVC pipe loosening a connection.
Go metal... all the way. Use silicone connectors from http://www.bakerprecision.com and 3" mandrel bent pipe for a 305, or 3.5" pipe for larger engines. The throttle body will take a 4.25" to a 3" adapter (or 3.5" depending on the size pipe you use) if I remember right. It's more expensive, but well worth the results.
Old Jun 3, 2004 | 01:18 AM
Guest
Guest
Posts: n/a
SoCal. I was in Fresno, even hotter there.
Polyethelene doesnt work.
PVC doesnt work.
ABS holds up quite well IMO. I bought the black stuff, I'd have to go look at the grade if someone really wants it but it doesnt matter. Its run of the mill sewer/waste pipe for home/business construction purposes. If it can survive in 100 degree summers with engine temps at 220+, I think its ok. Thats why I said ABS, PVC is flimsy and does not withstand the heat present under a hood. I had a nasty reminder of that just today with a temporary coupling for my blowoff valve tube.
Old Jun 4, 2004 | 06:31 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
ABS will withstand it... I live in Las Vegas and the summer here is 10 miles north of Hell. I ran ABS plastic for a "smooth bellows" mod and it withstodd the heat fine. I got rid of it, because it was a crappy mod and I didn't like its looks. Heat presented no problem tho.
BNOON - your piping is very nice looking, but you should really wrap it in a thermal sock or header wrap. It will help lessen the heating of air from transfer thru the metal tubing. Big difference in the summer time
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Navy8125
Aug 22, 2015 07:13 PM
Sanjay
Aug 12, 2015 03:41 PM
