timing
Old Jun 5, 2004 | 08:21 AM
flyboy367's Avatar
Car: 02 redfire gtp coupe
Engine: 3.8 modded and supercharged
Transmission: 4t65-ehd
timing
i found a 86z for a decent price but it has a bad timing chan. its a higher milage 350 i belive. how much of a pita is it to do the timingchain and maybe toss a small cam in?
Old Jun 5, 2004 | 12:34 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
its not too hard at all if you are planning to pull the engine to do it but if you wanna do it in the car its a litte bit of a pain because of the room you have to work with in these cars but its possible to do it so dont get discouraged the only hard part about doing it in the car is really getting the timing cover back on while its in the car ......alot of people cut the edges of the timing cover and grind it alittle and then cram it in i like to loosen the oilpan and then pry it down and put the timing cover back on then put some sealer on the pan gasket and reinstall it too but if its possible you might as well buy a gasket kit and pull the engine and replace all of em so you know your okay and wont have any leaks what so ever ...and it would make changeing the cam alot easier out of the car
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
