do i have the wrong alternator, or bracket?
Old Jun 9, 2004 | 03:31 PM
Jackman5003's Avatar
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
i'll take a picture later on...
the alternator i have comes no where near to lineing up with the bolt holes on my engine. you can see some pictures(take better ones later) on my site. and seeing we have had TBI and TPI parts laying around i figure maybe it got mixed up somehow.
any ideas? look at my site...
and also the belt that i KNOW if ment for this engine, doesn't fit at all.
look at the 8th picture from the bottom on the first page of my site.
Old Jun 9, 2004 | 03:42 PM
S10Wildside's Avatar
There's no way to tell from the pic you have on your website. Take several pics, front and back of the altenator on the bracket.
Old Jun 9, 2004 | 03:51 PM
Car: 1984 S-15
alright, when my dad gets home.
how would you know the differance? just from looks or is there anything specific?
Old Jun 9, 2004 | 03:59 PM
I can tell based upon the mounting points and the location of the alternator plug.
Old Jun 9, 2004 | 06:58 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think that is the incorrect alternator for the serpentine setup.. You need one with an offset mounting pattern (it looks like you have a straight one now)..
Old Jun 9, 2004 | 07:48 PM
Car: 1984 S-15
alright well i got those pictures up(page 6).
thinking about it, those would have to be the right brackets. because wasn't the TBI non-serpintine(don't know what to call it). just where would i get an alternator like that with serpintine???
and i called around to parts stores today hopeing they could tell me what one is MENT for the TPI, and i'd just get that and go from there. but all they could tell me was if it was 80 Amps or 100, which is it?
one guys had a computer that told the differance and said it was the 100 amp, didn't order it though...
Old Jun 9, 2004 | 09:27 PM
thirdgen88's Avatar
Car: 1995 Corvette
Just order one for a 1990 Trans Am with a 350.. it'll be a 105 amp CS-style alternator with the correct mounting provisions.
Old Jun 10, 2004 | 06:51 AM
Car: 1984 S-15
yea but couldn't i just get the TBI one or whichever one i need and just switch pullys?
Old Jun 11, 2004 | 08:51 PM
Car: 1984 S-15
alright i'll leave it at this....how many amps does the TPI aternator have?
100 amps you said? because napa brought both down from the warehouse...
i'll take pics if needed, because you probably know the deal, no returns on electrical items (thats y i'm so cautious about buying this thing...)
Old Jun 11, 2004 | 10:00 PM
thirdgen88's Avatar
Car: 1995 Corvette
It'll be the same one for the TBI car as well..
Old Jun 12, 2004 | 03:09 PM
Car: 1984 S-15
then why are there 2 differant amps? and which one should i get? and you think it would work with my brackets?
Old Jun 14, 2004 | 05:45 PM
Car: 1984 S-15
ok well, would the TBI one work on the TPI one? no right?
Old Jun 14, 2004 | 09:15 PM
thirdgen88's Avatar
Car: 1995 Corvette
yes, they will both work... Same brackets on both induction setups ('88-'92).
Old Jun 14, 2004 | 09:21 PM
Car: 1984 S-15
lol. well since i KNOW this is either TBI or TPI bracket setup(or a mix of the both)....then...whats the problem? i just need to know which amp alternator to get then right?
i got pictures going up right as i'm typing this on the site. will be up soon.
and wheres this casting number? because this MIGHT JUST BE an 87 bracket....
Old Jun 17, 2004 | 12:04 PM
Drew's Avatar
It'd be easy to tell if you have the wrong brackets. There are serpentine brackets and then there's everything else. Serpentine brackets are cast aluminum, silver in color. Every other bracket they used on the Fbodies were steel, painted black.
If the alternator doesn't fit the bracket, you have the wrong alternator.
Old Jun 17, 2004 | 12:39 PM
Car: 1984 S-15
i know its serpintine because it had a power steering pump on it that was never taken off which had a serpintine pully on it. and now i know its the wrong alternator...
i'll rephrase the question..."what alternator do i need" but seeing there both the same on TBI and TPI..."what amperage do i need, 85 or 100?" it doesn't have ac(any more....its not going to be used)
Old Jun 17, 2004 | 04:28 PM
It probably doesn't matter which one you use. This is more of an electronic question than a TPI question. You should ask this question in the electronics forum.
Old Jun 17, 2004 | 05:30 PM
Car: 1984 S-15
alright thanks again wildside
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
